Auto to stick need help!!!
Old May 28, 2005 | 11:20 AM
P2R4DREF's Avatar
Default Auto to stick need help!!!
I want to know how hard is it to convert a 4DR EF from auto to stick. What is needed other than tranny, clutch, flywheel, pedal, and cable. Any help is appreciated Thanks.
Old May 28, 2005 | 11:24 AM
d16efsedan's Avatar
Default Re: Auto to stick need help!!! (P2R4DREF)
i did this on my hatch and to be honest the hardest part was the peddle assembly.where you unplug your automatic shifter there is a plug with 2 black and white wires you have to bridge those in order to start it by the key,you also have to run the reverse lights on the tranny into the car but im not sure where to hook them up at cause i never did...i'll try to find a write up for you..good luck
Old May 28, 2005 | 11:25 AM
runitup's Avatar
rear mount and bracket, tranny mount,
Old May 28, 2005 | 11:26 AM
runitup's Avatar
http://hometown.aol.com/jrmupzaii/auto2man.html
Old May 28, 2005 | 11:27 AM
d16efsedan's Avatar
Default Re: Auto to stick need help!!! (d16efhatch)
http://members.aol.com/jrmupzaii/auto2man.html http://www.50mod.com/fourthgenhatch/auto2man.php there ya go...should be all the info you need.
Old May 28, 2005 | 11:34 AM
P2R4DREF's Avatar
Thanks you guys helped me out alot
JDM_DC4_Fanatic
Nov 13, 2005 07:11 PM
Patrick FS
Feb 25, 2003 02:12 PM
1.8EG-T
Feb 4, 2002 06:57 PM
