Mini-me swap parts list ??
I know that I need :
Z6 head from 92-95 SI Vtec
Z6 or Y8 head gasket
Z6 or Y8 head Studs
Ecu P28
Jumper Wire From OBD0 to OBD1 to fit the Ecu in
Z6 timing belt
Do I need a 4 wire O2 sensor and a new Distributor from the Z6 or can I keep the 1 wire O2 sensor and distributor from my SI 91 ???
Someone can help ??
Z6 or Y8 head Studs
Ecu P28
Z6 timing belt
Someone can help ??
yes, but when I bought my head the distributor didnt came with it. Did you keep your original from the CRX or did you bought the 92-95 one ?? and which O2 sensor did you ended with ??
Mine is still OBD0, so I used the d16a6 dizzy, and did a bit of cutting to make it fit. That meant I could keep my O2 sensor, and not have to do any wiring. You will also need spark plug wires and plugs for the Z6 head.
There is a guy on another board who is chipping stock Si ECU's with the Z6 maps and a Vtec output, I plan on just getting that done instead of doing the OBD1 switch.
yes, i plan on getting OBD1 but still without any diagnostic connector, for this, i hope I wont have any Check light, lolll, but yes, I think I do need the distributor and the O2 sensor ... but I wonder if I could just use my 1 wire O2 instead of the one with the slef heating ...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DarKAvEnGeRz »</TD></TR><TR><TD CLASS="quote">but anyone know what are the diff of the distributor from OBD1 and OBD0 ?? why wouldnt my OBD0 work with my P28 Ecu ??</TD></TR></TABLE>
it uses a different trigger i believe. Where is the rywire guy at? He knows this crap better than me.
Cuong-nutz
Mar 11, 2005 10:13 PM
