Help, Fuel Filter....
Old May 28, 2005 | 10:36 AM
tholub003's Avatar
Default Help, Fuel Filter....
How do I release pressure in a fuel filter before removing it in a 1993 honda civic dx?
Old May 28, 2005 | 12:23 PM
davidluko's Avatar
Default Re: Help, Fuel Filter.... (tholub003)
Just plug your eyes, turn your face away from the filter, and unbolt That's how I know to do it. You can keep a rag around it as you're unbolting to keep fuel from spraying too much.
EDIT: I'm sure there's a better way though, if you don't feel comfortable doing what I said then wait for an expert
Old May 28, 2005 | 01:16 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tholub003 &raquo;</TD></TR><TR><TD CLASS="quote">How do I release pressure in a fuel filter before removing it in a 1993 honda civic dx?</TD></TR></TABLE>
Remove the gas cap and loosen the service bolt at the filter.
Old May 29, 2005 | 08:16 AM
1SlowB16EF's Avatar
how about removing the fuse for the fuel pump and cranking the engine over to releive the pressure?
Old May 29, 2005 | 08:45 AM
T4eg's Avatar
Default Re: Help, Fuel Filter.... (Chiovnidca)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chiovnidca &raquo;</TD></TR><TR><TD CLASS="quote">
Remove the gas cap and loosen the service bolt at the filter. </TD></TR></TABLE>
Old May 29, 2005 | 09:13 AM
Chiovnidca's Avatar
Default Re: (1SlowB16EF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1SlowB16EF &raquo;</TD></TR><TR><TD CLASS="quote">how about removing the fuse for the fuel pump and cranking the engine over to releive the pressure?</TD></TR></TABLE>
That wont do anything, it disables the injectors too. You could unplug the fuel pump, but why bother?
Old May 29, 2005 | 11:27 PM
fllwyb's Avatar
I have a fuel gauge on my fuel line. It would drop to zero after 5-10 minutes. Just wait a little bit and use papper towel for any drips. And yeah remove the gas cap.
allhonda
Oct 8, 2008 07:30 PM
The Dirty EJ1
Apr 10, 2008 03:58 PM
zach1288
11
Jan 2, 2007 06:39 PM
CBURKE
Jul 26, 2006 06:30 AM
Rpizzle
Apr 7, 2005 09:37 AM
