Need help, TPS settings
Old May 28, 2005 | 08:14 AM
shadykit's Avatar
Default Need help, TPS settings
I'm having problems setting my TPS voltage.
I used a voltagemeter to measure it at .5 volts but at WOT it's at 4.97 volts which still gives me a CEL 7.
Am I measuring it right?
Old May 28, 2005 | 04:32 PM
shadykit's Avatar
Default Re: Need help, TPS settings (kitchale)
anybody?
Old May 29, 2005 | 08:25 PM
dmingis's Avatar
I'm struggling with my own TPS problems. In your case, the repair manual says to swap in another ECU and see if the problem goes away.
Old May 29, 2005 | 09:31 PM
8krdline's Avatar
try setting it at like .45 idle and see if that helps
Old May 31, 2005 | 07:34 AM
shadykit's Avatar
Default Re: Need help, TPS settings (8krdline)
I've tried .32 and .45 and it still gives me a CEL after a hard run.
I've also change to a known working TPS sensor and still no go.
I'll try to that ECU swap...see how that goes.
Old May 31, 2005 | 11:18 AM
RedZone's Avatar
what car, what engine, what year ecu......
Old May 31, 2005 | 01:45 PM
egsleepercivic's Avatar
adjust it as close as possible to stock if you already tried a different tps and got the same result it is either the ecu or the wiring. I would say that it is the wiring but ya never know
Old May 31, 2005 | 02:22 PM
shadykit's Avatar
Default Re: (egsleepercivic)
Well everyting was working fine and then it just happened out of nowhere when I never touched the TPS.
99 GSR running P28 Jun chip
Old May 31, 2005 | 02:28 PM
shadykit's Avatar
I can get the closed throttle at .45 or .5, but I can't get the WOT at 4.5
It's giving me 4.97 or so
Old Jun 1, 2005 | 12:53 PM
test the continuity of the wires, your helms should tell you how to do this
Old Jun 1, 2005 | 01:52 PM
shadykit's Avatar
How do you do that, I don't have a helms?
Old Jun 1, 2005 | 02:23 PM
I'll have to look at my helms tonight I can try and let you know tomorrow, unless somebody has 1 in front of them right now
1Bluegsr
Jan 16, 2010 12:12 PM
lshatch1.8
Jan 8, 2008 12:33 AM
wheels01
Jul 4, 2005 05:34 PM
imlachg1
16
May 22, 2004 06:04 PM
Darkteg
Aug 17, 2003 12:47 PM
