first swap need help
okay so i have a 93 coupe and i have a blown head gasket. so i got an 96 ls non vtec motor..what i need to know is what ecu do i use. cause the honda is obd1 and the teg is obd2.i know i will have to wire it up but what year teg ecu do i use? oh yeah worst part for last is that its an auto
this is a quote from an older body, thank you longbeachpurplecivic
92-95 EG & Del Sol with a 94-2000 Integra LS B18B Engine.
Transmission: These Engines come with Hydraulic clutch transmissions including Japanese or American market Y21, Y80, S80, AND S4C. Japanese or American market S1, J1, A1, Y1 or YS1 cable clutch transmission with Hasport cable conversion kit part # M92-CC can be used.
Mounts: A combination of stock and integra mounts can be used if a hydraulic B- series tranny is used. on some 96 and up engines you may need to change the bracket under the timing belt and on the rear of the engine for ones of the appropriate year.
ECU: p75 from a 94-95 Integra
Electrical Differences: CX and VX need to convert to 4 wire o2 sensor. All models modify stock harness to fit.
Axles: 90-93 integra axles, 94-up integra axles, 94-97 Del Sol Vtec axles, or 99-00 Civic Si Axles. Note the intermediate shaft seal in the left side of transmission is different for 90-93 Integra Axles. Depending on Axle transmission Combo, It may have to be changed. Hasport Part#: EGBAXCMP
Shift Linkage: 94-up Integra linkage for Civics. 94-97 Del Sol Vtec linkage for Del Sol
Upper Radiator Hose: 94-Up Integra LS
Lower Radiator Hose: 94 Del Sol Vtec
Throttle Cable: 94 Integra LS
Clutch Hydraulics: Stock
Air Conditioning: 94-95 Del Sol Vtec A/C bracket
Special instructions: Using OBD II Ecu requires involved wiring modifications. Generally if the ECU you choose does not use the same plugs as the stock ECU, an Adapter harness will cut down on alot of potential problems
Special Considerations: Nice motor, Smog Legal, and excellent base for turbo car. Smog Legal in
Slap on a VTEC head and get a manual tranny!
haha if not, you need a P75 auto ecu, and since you have the OBD1... you basically need the 94-95 Integra LS Auto ECU...
Is the b18 an auto? or is your car currently an auto?
If the b18 is an auto then you will just need to switch out the flywheel for a b18 manual flywheel. (Least that is what I was told)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mksop »</TD></TR><TR><TD CLASS="quote">thanks guys. im gonna do a bit of both daily driving and some track racing. both cars are autos.what i have now is motor trans harness and axels so i think all ineed is the ecu</TD></TR></TABLE>
You're not track racing dick with a Honda automatic transmission, just for the record
JDMlyfestyle
84
Jul 23, 2020 02:14 PM
B16ACivichtch
Oct 28, 2006 11:44 AM
