Brake Lamp ....
Old May 27, 2005 | 04:56 PM
Duster's Avatar
Default Brake Lamp ....
I have an 86 accord. Whenever i start the car there is nothing abnormal lit up on the dash...as soon as i put my foot on the brake to put it into reverse (its automatic) the "brake lamp" indicator pops up on my dash....It stays on till i turn my car off...
I have checked all the brake lights, as well as backup lights and running lights....nothing is burnt out or ecstatic.
I have checked the master cylinder to see if maybe fluid was low....it was not....
I have bled the brake lines and cleaned and adjusted the rear drum brakes...
I checked the front brakes and there is lots of life left...
Nothing has worked....Any idea what could be causing this light to come on?? Like i said it doesn't come on when i first turn the car on, only when i go to take it out of park. thanks guys!!
Modified by NotherHonda at 2:41 AM 5/28/2005
Old May 27, 2005 | 05:59 PM
deserthonda's Avatar
it could be the brake lamp sensor ,,there is one on each tail lite assembly it is where the brake lite wiring plugs in
Old May 27, 2005 | 06:04 PM
Duster's Avatar
Default Re: (deserthonda)
does it look like a relay? that could be it....if i knew what i looked like i could figure it out preatty easy....any suggestions?? thanks deserthonda!
Old May 27, 2005 | 06:09 PM
it does not look like a relay it is mounted by 2 or 3 screws and mounted right on the tail lite assembly
Old May 27, 2005 | 06:10 PM
jmouchett's Avatar
Default Re: (NotherHonda)
You also need to check the ground connection in the trunk for the taillights. I forgot to do that, and my lights were all screwed up for a few weeks
Old May 27, 2005 | 06:17 PM
Duster's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deserthonda &raquo;</TD></TR><TR><TD CLASS="quote">it does not look like a relay it is mounted by 2 or 3 screws and mounted right on the tail lite assembly </TD></TR></TABLE>
alright i'll pull my taillight assembly off later and check for that sensor. should be preatty cheap to replace eh?? I guess id have to get 2 sence i don't know which side the sensor is goofed....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jmouchett &raquo;</TD></TR><TR><TD CLASS="quote">You also need to check the ground connection in the trunk for the taillights. I forgot to do that, and my lights were all screwed up for a few weeks</TD></TR></TABLE>
Humm...my lights work fine, and its every single time i take it out of park, not just here and there....
Old May 27, 2005 | 06:29 PM
Duster's Avatar
hey deserthonda, i pulled off the brake light cover and i see something held in by 2 screws ..a little black box..one on each side ......is there anyway i can test to see which one failed?? using a test light or anything....Your talking about the brake light assembly in the trunk not the trunk lid right? cause there is 2 black boxes in there too...
Modified by NotherHonda at 3:45 AM 5/28/2005
Modified by NotherHonda at 4:56 AM 5/28/2005
Old May 27, 2005 | 11:00 PM
yo nother,, that is the box i am talking about but i just realized something that i did not think about before....the brake lite that comes on is it the 1 that is got the picture of a car and also lite up when you have door open??? or is it the main brake lite on dash tht comes on when you apply e-brake???
if it is 1 that has pic of car then whichever side is lit that is the box that is faulty ...using a test lite i would need an etm to trace wiring color to chk power going into and out of box,,
if it is the main 1 that comes on when you apply emergence brake than the problem is not the box let me know ..
Old May 27, 2005 | 11:23 PM
Confuc1ous's Avatar
I'm gonna have to check mine, the light is on for my dash also. I think i need to change out the sensor on mine.
Old May 28, 2005 | 01:57 PM
fubuallstar's Avatar
Default Re: Brake Lamp .... (NotherHonda)
it sounds light a brake light failure sensor. it works on resistance. little black box. u cant really test them open it up and check to see if the contacts are black or gray and smells burnt.
Old May 28, 2005 | 02:54 PM
Duster's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deserthonda &raquo;</TD></TR><TR><TD CLASS="quote">yo nother,, that is the box i am talking about but i just realized something that i did not think about before....the brake lite that comes on is it the 1 that is got the picture of a car and also lite up when you have door open??? or is it the main brake lite on dash tht comes on when you apply e-brake???
if it is the main 1 that comes on when you apply emergence brake than the problem is not the box let me know ..</TD></TR></TABLE>
Its not the emergency brake light. It is the light on the little car like you said, the one that lights up when the door is open. but there is not sides on that little light it just says "brake lamp" and takes up the whole back of car....I am going to order 2 of the brake lamp sensors on monday and replace them both and hope that will work, i'll let you know desert! thanks for your help!
Old May 28, 2005 | 05:51 PM
iam7head's Avatar
beside all that, check the sensor for the brake fluid tank, it might be stuck or disconnected.
do reset the ecu after all fixing to clear it up
Old May 28, 2005 | 06:29 PM
yo iam7 ,,just so you know the brake sensor in the master cylinder will only cause the main brake lite come on the dash same as when you apply e-brake ,,not the 1 as if a bulb is out and on an 86 there is no ecu to reset
Old May 30, 2005 | 05:29 PM
vedha's Avatar
I have the same problem honda accord 1990.
I am waiting for an answer
Old Jun 4, 2005 | 02:30 PM
JDM-Gurl's Avatar
Default Re: (vedha)
I have the same problem. I drive a 1990 accord and for the past couple weeks my brake lamp light has been on and my boyfriend and i cant figure out what to do.
Manmeetsingh
May 20, 2014 08:06 PM
dungsta
Dec 2, 2005 07:52 PM
slowassR
Sep 3, 2003 08:43 AM
persain488
Nov 12, 2002 05:24 PM
