no reverse while car is running
Old May 27, 2005 | 02:35 PM
torr's Avatar
Default no reverse while car is running
it'll go into gear while the motor is not running, but will not go into reverse while the car is running.
no big deal for me but, why wont it go into revesre when the car is running?
Old May 27, 2005 | 02:38 PM
fireisfun's Avatar
Default Re: no reverse while car is running (torr)
manual or automatic?
Old May 27, 2005 | 02:39 PM
torr's Avatar
Default Re: no reverse while car is running (fireisfun)
manual, and i bled the clutch
Old May 27, 2005 | 02:41 PM
fireisfun's Avatar
does it grind at all when you try to put it into reverse?
Old May 27, 2005 | 02:42 PM
torr's Avatar
no grinding
weird, it only happens when the is running
Old May 27, 2005 | 02:46 PM
fireisfun's Avatar
check the shift linkage then...if it was clutch related it should grind (like it you try to put it into gear without putting your foot on the clutch). It could also be the reverse synchro but not for sure.
Old May 27, 2005 | 02:56 PM
torr's Avatar
linkage is cool, reverse has no synchros. it just a gear on a rod, actauted by a lever. thats why it's weird to me.
Old May 27, 2005 | 03:01 PM
fireisfun's Avatar
hmmm...my next thought would be drain the tranny and check for metal...sry cant be of more help
Old May 27, 2005 | 03:05 PM
torr's Avatar
good looking
Old May 27, 2005 | 11:30 PM
torr's Avatar
bump
Old May 29, 2005 | 10:32 AM
torr's Avatar
bump
Old May 29, 2005 | 01:48 PM
DaZman69's Avatar
does it feel any different when you pop it out of reverse when the car is running?
Old May 29, 2005 | 03:47 PM
torr's Avatar
Default Re: no reverse while car is running (DaZman69)
no, feels normal
Old May 29, 2005 | 08:47 PM
torr's Avatar
here's what im thinking
when the cars off, the mainshaft is not spinning so that the reverse gear slector is doing all the work changing it into reverse.
when the cars running, somethings binding it up
BuyBrakes.com
Transmission & Drivetrain
Mar 9, 2012 09:33 AM
tallguy21
17
Feb 27, 2011 05:49 PM
88CRXJ
Sep 24, 2009 11:56 PM
spooncivic1
Jan 8, 2006 07:14 PM
BlackOutIntegra
May 6, 2004 10:47 AM
