which diagram do i use for a v-afc install on a del sol vtec (b16a3)?
Old May 27, 2005 | 11:04 AM
juiceman33's Avatar
Default which diagram do i use for a v-afc install on a del sol vtec (b16a3)?
I searched, I found a bunch on apexi's website, but i dont know which one to use. thanks alot.
Old May 27, 2005 | 11:15 AM
pdiggitydogg's Avatar
What do you mean which one?
Is it a vafc I or vafc II?
I http://www.apexi.com/pdfInstallation/23.pdf
II http://www.apexi.com/pdfInstallation/25.pdf
Old May 27, 2005 | 11:27 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (pdiggitydogg)
If you are installing this yourself, pay VERY close attention to the wiring, and SOLDER all the connections... use heat shrink if you can, if not good 3M electrical tape. You can't rig this part or your car will run like ****. If at all.
Old May 27, 2005 | 11:33 AM
juiceman33's Avatar
its a vafc I... yeah, i'm gonna just tap into each of the wires and solder them
Old May 27, 2005 | 03:24 PM
juiceman33's Avatar
Default Re: which diagram do i use for a v-afc install on a del sol vtec (b16a3)? (94delslowb16)
any help??
Old May 27, 2005 | 03:34 PM
You got what you asked for
Old May 27, 2005 | 04:36 PM
juiceman33's Avatar
yeah, i have the instructions that came with it... i just dont know which of the diagrams to use... there is no del sol in the booklet, nor is there anything for a b16a3. I need to know which one of those diagrams to use.
Old May 27, 2005 | 06:49 PM
of course there isnt...
Its obd1
Find the correct wires.
Old May 27, 2005 | 07:10 PM
pb16b's Avatar
use diagram of ecu... if it's p72 obd1, use diagram for gsr. etc. etc.
Old May 30, 2005 | 08:15 AM
DSoDry's Avatar
i smoke rocks
P.S. PPPRRRR
Old May 30, 2005 | 09:25 PM
juiceman33's Avatar
Default Re: (94delslowb16)
yeah... well... no one really helped there... i got it hooked up, in case anybody else has a problem like this, the correct diagram is H2-A. yeah.
Old May 31, 2005 | 01:04 PM
DSoDry's Avatar
good thing your cousin knows what he's doin. these stupid bitches dont know ****.
civic89si666
Apr 11, 2006 08:45 AM
Del_Sol_s
Nov 6, 2005 02:14 PM
Ty.
11
Jan 18, 2004 10:10 PM
teknics1
Aug 17, 2003 05:17 PM
Neukin
Feb 20, 2003 07:20 AM
