VAFC in a DEL SOL???? HELP
Ok i just boughta VAFC 1 and in the manual it has a list of cars it works on with wiring diagrams of each to install it. the only problem is the del sol vtec is not one of them! i am sure i can hook it up but i just need to know which diagram to follow out of them. does anyone know or know where i would be able to find this out at?
Thanks
Ty
Thanks
Ty
Re: VAFC in a DEL SOL???? HELP (BLACKEG2)
what year is your Sol? If it's 96+ or even a 95 w/ a B16A2 (heard somewhere a limited number of 95's had the obd II engine, but not positive on this) it should be the exact same wiring as the 99-00 Si, and prolly not very different for the A3 (94 & 95) unless it taps into some of the stuff that the OBD II changed or whatever...
Re: VAFC in a DEL SOL???? HELP (AzntaggeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzntaggeR »</TD></TR><TR><TD CLASS="quote">hey where are you going to mount your vafc? need some ideas for a del sol.</TD></TR></TABLE>
Pooping on children
oops i dont even own a sol
Re: VAFC in a DEL SOL???? HELP (BADEG6)
There is no place to mount it. I mounted mine in front of the gauge cluster so its sorta hidden(not really). Uhm and you should have a p28 so just do the wiring like its a p28.
TSPeed Factory
i have the manual right here and it says integra ls/gsr (dc2, da6), civic ex, si (eg, ek) all follow the h2-a diagram. so just wire it up in ur del sol and follow any of those diagrams and it'll work.
thanks azntaggeR i was thinking that but i just wanted someone elses opinion. and to answer your first ?? i am actually planning on making some kind of mount to put it right in fron of my climate control and have it hinged to flip up out of the way to adjust the control on the temp. we will see i may just end up mounting it right to my dash.
Ty
Ty
juiceman33
11
05-31-2005 01:04 PM
