What code is this?
Old May 27, 2005 | 11:02 AM
Turbo-Honda's Avatar
Default What code is this?
Could someone tell me what code is this?
I put jumper on the clip.
Turn ign to on position, dash lid up; check engine blink off for 2 sec then on for 2sec then 6 fast jump.
Is this consider 6 or 16?? I think it was 6 temp sensor because of my motor is real hot; from hoses to valve cover to engine, tranny, rad etc... Fan is on because i mount it to a switch. But i'm not overheating, needle at middle.
Does anyone have the same problem when starting up a new build motor with block mod?? Does the entire engine bay got hot??
Motor just rebuild 9.1cr, 84mm, wisco piston, eagle rod.
Thanks for the help..
Old May 27, 2005 | 12:47 PM
JimBlake's Avatar
Default Re: What code is this? (Turbo-Honda)
If there's a couple-second pause before the 6 fast blinks, then it's two different codes, 10 & 6.
10 = intake air temperature sensor
6 = engine coolant temperature sensor
If the 6 flashes follow immediately after the long one, then it's code 16.
16 = fuel injector. Look for loose/dirty/flaky wiring to each injector.
Old May 27, 2005 | 09:10 PM
First the light turn off when ign on. Then it pop on 2 sec then 6 fast one like what you said. So my bet is 16 fuel injector was it? I positive my fuel clip is ok. Injectors looks ok too but 1 of em, the hard plastic yellowist part is broken on top of the injector going into the combusion chamber. I wonder if is this one?
Old May 28, 2005 | 05:04 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-Honda &raquo;</TD></TR><TR><TD CLASS="quote">
Is this consider 6 or 16?? </TD></TR></TABLE>
Sounds like 16. Ever have a problem starting the car after it sit out in the sun. A bad main relay can cause that code.
Old May 28, 2005 | 05:07 AM
Chiovnidca's Avatar
Default Re: (Turbo-Honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-Honda &raquo;</TD></TR><TR><TD CLASS="quote"> Injectors looks ok too but 1 of em, the hard plastic yellowist part is broken on top of the injector going into the combusion chamber. I wonder if is this one? </TD></TR></TABLE>
Make sure it's getting a good connection to the injector. You could check the resistance of all the injectors too. They should all read about the same.
Old May 28, 2005 | 08:09 PM
Was it the injector resistance or injector clip I should check? 10-13ohm for the clip right? what about resistance on the injector it-self? How much is that?
Old May 30, 2005 | 06:27 PM
I found it was 16 .. One of my injector clip is not functioning. What could I do to fix the problem? I have an extra clip, should I swap it in? or check something else first??
obd1 95 acura
Old May 31, 2005 | 04:15 AM
JimBlake's Avatar
How is the clip not functioning? Does it simply not stay attached to the injector? Loose wires? Or what?
You said one injector is cracked - that sounds suspicious to me... Measure the resistance of the injectors, see whether they're the same. If one is way different, replace it.
Old Jun 5, 2005 | 08:30 PM
Found the problem. My darn Ecu is not functioning correctly. When I swap to a different ECU, problem goes away. I wonder what happen? I mean I didnt touch the ECU at all. Wonder Y.
Old Jun 5, 2005 | 08:58 PM
Redcoupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo-Honda &raquo;</TD></TR><TR><TD CLASS="quote">Found the problem. My darn Ecu is not functioning correctly. When I swap to a different ECU, problem goes away. I wonder what happen? I mean I didnt touch the ECU at all. Wonder Y.</TD></TR></TABLE>I have this same problem. Check your plugs, thats what I gotta do tommorrow.
mytime
Jan 26, 2014 12:47 PM
eg9d16turbo
Sep 7, 2011 04:24 PM
JRG151
10
Jan 21, 2010 02:55 PM
Lo-Buck EF
16
Aug 22, 2003 05:39 AM
