i need some help bad, with my turbo
Old Feb 7, 2002 | 07:22 AM
rob1208lv's Avatar
Default i need some help bad, with my turbo
hi i have a turbo (drag3) ls i up graded to 310cc injectors, missing link, and greddy profec-b controller. first can i up the boost to 10lbs daily driver?? some peps say ya your be fine others say no only go as high as 8Lbs. second what the best fuel management to buy? im buying a tial wastegate, i just think i should buy fuel somthing first. whats the best way to tune my car?? low/mid or high???
[Modified by rob1208lv, 9:49 PM 2/11/2002]
Old Feb 7, 2002 | 07:32 AM
Rob03Pro5's Avatar
Default Re: i need some help bad, with my turbo (rob1208lv)
First thing: Do you still have the 12:1 FMU? If so, you'll be running extremely rich.. but at 10psi, i'm thinking the extra air might bring down the A/F a bit. There have been LS's that run 9psi daily.. on the DRAG 3 with NO alterations.. so seeing that you'll have more fuel, I'd say go for it.. but be careful and try to tune it. I'd back away some timing just to be safe.
Of course your best management will be Hondata. I'd get that and ditch the 310's for something like 440's or more.
Old Feb 7, 2002 | 08:16 AM
rob1208lv's Avatar
Default Re: i need some help bad, with my turbo (Rob92SC)
thank for your help
Old Feb 11, 2002 | 12:50 PM
rob1208lv's Avatar
ttt
Old Feb 11, 2002 | 02:49 PM
Smashback's Avatar
Watch that FMU - make sure your pump can supply enough fuel at that pressure level (120 lbs)
J337_UNIT
Jan 21, 2004 06:52 PM
xcivicdx
Mar 24, 2003 03:19 AM
TSIntegra
Jul 8, 2002 02:43 PM
Cyrio
Feb 4, 2002 05:22 PM
MugenVtek4
Dec 13, 2001 07:52 PM
