GSR dizzy wiring problems in 99 civic! Extra wires?
I have searched all over the place and cannot find the answers to my problem(s).
I was told the harness should have clipped directly into the Gsr dizzy, well of course things cant be THAT easy.
So I'll list the wires that I have on the Gsr dizzy (00 obd2) and 99 Civic harness.
B18c1... Blu/yel, blu/grn, Blu(thicker), Wht, Wht/blu, Blk/yel, yel/grn, org?, org/blu.
D16y8 harness.... Blk, Red, Wht, Blk/yel, yel, Grn, Blu, yel/grn.
This is how I have them connected as of now. (car is not running right and throwing a ckp CEL.)
D16 harness -> b18 dizzy
yel/grn - yel/grn
Blk/yel - blk/yel
wht - wht
yel - org
grn - org/blu
blu - blu/grn
red - wht
I was told that the thick blue wire on the gsr dizzy does nothing (there was no blue wire on the gsr harness either)
I have a Blue/Yel wire left over on the dizzy side
and a Blk wire left over on the d16 harness.
I am not sure if all of the wires are matched up correctly but if anyone could give me some information on this it would be greatly appreciated.
yel/grn - yel/grn
Blk/yel - blk/yel
wht - wht
yel - org
grn - org/blu
blu - blu/grn
red - wht
OK after trial & error I've cleared all codes except for the 22 (vtec pressure switch?)... I replaced the switch and its still throwing that code, and the engine won't rev above 5k rpm, anyone know why this is?
I had the same problems a few years back. I had the incorrect distributor. Check to make sure you have the correct one.
are you using a stock obd2 gsr ecu?
make sure the vtec pressure switch wiring is going to "C" 15 at the ecu. (c is the middle sized plug) wire should be blue & black. look at the ecu connector from the back (looking from where the wires go into the plug). count 5 accorss from the left on the second row.
use a voltmeter and set it to continuity. it should make "beep" sound or show up on the volt meter if the wire makes a solid connection.
pics courtest of Katman from ff-squad.com
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allen7-civic »</TD></TR><TR><TD CLASS="quote">should have taken both dizzys apart.
Taken the guts from the d and put in the b series cap. problem solved. </TD></TR></TABLE>
i did that.. its started once.. then wont start again.. is that the problem the dizzy?? man my car hasnt started for a month.. i cant seem to figure out if the dizzy is the problem...
no car is a 00 EX.. motor is a LS.. im using my stock harness... im gettin spark.. fuel everything.. sometime when i try to start the car the fuel will prime but wont start.. then when i try again the fuel wont prime until i mess with dizzy...
Okay... I am really confused. There are like 3 different people posting the same questions. One says they have a GSR, the other says its an LS. WTF is going on here?!!!!
92_VX_EG
Jun 4, 2008 12:14 PM
bogus_ek
Mar 27, 2005 08:10 AM
