Stock Ecu with B18C motor
Old May 27, 2005 | 08:33 AM
kobeRy_si's Avatar
Default Stock Ecu with B18C motor
im currently in the process of dropping in a 99 JDM B18C into my 99 Civic Si.. problem is, i have not yet found a ECU.. i know im able to run my stock ECU, but will there be any problems>? will i end up with a check engine light>? what are the main consequences>?
thanks.. and yes i did search.. but once again.. i suck at searching..
Old May 27, 2005 | 09:56 AM
IHateJDM's Avatar
Default Re: Stock Ecu with B18C motor (kobeRy_si)
i don't know how it will run, it really isn't a good idea to swap a motor without the right ecu first. since it's from a b16, it'll probably run the motor, but it won't run right.
Old May 27, 2005 | 10:20 AM
sic my duc's Avatar
i got a p72 obd1 for sale, virgin also, let me know
Old May 27, 2005 | 11:29 AM
timisyourfriend's Avatar
It'll run, but won't run like you'd want it to and especially with a Type R motor... lol You can either get a OBD1 conversion and run a P28, P72, etc. Or you can stay with OBD2 and use a P72 or P73, either way, have it tuned! HONDATA! or at least VAFC...
Old May 27, 2005 | 02:02 PM
99exd16y8's Avatar
Default Re: Stock Ecu with B18C motor (JZPerformance)
yeah i did a 00gsr swap into a 99 ex coupe and used the ex ecu to start the car up b/c of the immobilzer on the gsr ecu, it will run it put it want be to its full potential.
BrandonB16
Feb 17, 2009 05:33 AM
DOHC Kid
May 27, 2008 05:41 PM
jvonb
Nov 13, 2005 02:02 PM
insomniac791
Dec 8, 2003 04:19 PM
SlackerX
Jun 19, 2003 02:56 PM
