no vtec, code 21
Old May 27, 2005 | 03:05 AM
kylemarhx's Avatar
Default no vtec, code 21
i just swapped a 1st gen jdm b16a w/ hydro gsr tranny into my '95 dx coupe. the ecu i'm running is a p28 running uberdata with the vtec pressure switch disabled. i have the hasport vtec subharness, i ran the green wire in the harness from the vtec solenoid to pin a4 on my ecu. it's throwing a code 21 (vtec solenoid) and i can't seem to figure it out. i've even tried running a wire stright from the solenoid to pin a4 without the subharness just in case hasport screwed up somewhere but that didn't work. i know uberdata is all chipped right 'cause my rev limiters i've set are working. i tried running direct power to the solenoid and it popped fine. i've checked the screen on the solenoid and it's clear as can be. i'm running out of things to try and am hoping that somebody here can help me out. thanks.
Old May 27, 2005 | 09:49 AM
kylemarhx's Avatar
bump for help please. i've searched and tried everything i have found but still no dice.
Old May 27, 2005 | 06:17 PM
mtber's Avatar
Default Re: (kylemarhx)
Piggy back the vtec pressure signal off the vtec solenoid signal at the ecu.
Modified by mtber at 9:44 AM 6/27/2005
MugeNinja
Dec 29, 2005 09:50 AM
VTC_CiViC
Nov 17, 2004 09:05 PM
flat-blk-HB
Oct 5, 2002 09:28 AM
InfamousRS
May 21, 2002 04:09 PM
