Compression Ratio Question
I did a bit of searching around including the huge compression ratio thread on CTR (pct) pistons... However i still did not find what i was looking for.
I know that there is a huge confusion issue with the whole C-speed Racing calculator. So any help that you could give me would me most appreciated.
Its a b18a 81.25 mm bore (no decking)
pct pistons
b18b head (no milling)
95ls rods (pretty sure it dosent matter but thought i would throw it in anyway)
oem head gasket
What should my compression ratio be?
Thank you in advance
pct pistons
oem head gasket
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18Tahtaras »</TD></TR><TR><TD CLASS="quote">
pct pistons
oem head gasket
You would be at 12.4:1 by this calculator below. Piston to deck hieght should be 0.00" but you can measure when you assemble to be sure. I had PCT's in My LS and now I have P73 00's and my PTDH was 0.08".
http://www.zealautowerks.com/
pct pistons
oem head gasket
</TD></TR></TABLE>You would be at 12.4:1 by this calculator below. Piston to deck hieght should be 0.00" but you can measure when you assemble to be sure. I had PCT's in My LS and now I have P73 00's and my PTDH was 0.08".
What cams are you running?
Are running OBD-0 or OBD-1
When I had PCT's and used Crower 62404's I loved my setup. dynoed 170whp and ran times in my sig. below.
No problem! I have a P06 that I have already chipped to a Mugen copy P75 for a good price. This is the program I ran with my CTR's and 404's with stock head. It has a rev limiter of 8.5k and a more aggressive fuel curve. It worked great with 93 octane. Let me know if your interested and I will give you a price. IM me!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcter g »</TD></TR><TR><TD CLASS="quote">You will love the 404's........Why are you using a P28 instead of a P06 or P75????</TD></TR></TABLE>
is there a difference in using a p28 instead of a p75?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SecretAgent »</TD></TR><TR><TD CLASS="quote">usually when they chip ecu's they disable the CEL function for VTEC codes, so he shouldn't have any CEL's.
and lol @ the mugen copy P75. mugen never made a program for the B18A/B to copy.</TD></TR></TABLE>
BTW.....are you a computer nerd?
i have all the equipment for burning the maps on. So i should be able to figure out how, or atleast turn off the CELs for the missing vtec solenoid and pressure sensors. We'll see.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18Tahtaras »</TD></TR><TR><TD CLASS="quote">I did a bit of searching around including the huge compression ratio thread on CTR (pct) pistons... However i still did not find what i was looking for.
pct pistons
oem head gasket
Your actual compression ratio will be 12.2245:1 with that setup.
pct pistons
oem head gasket
</TD></TR></TABLE>Your actual compression ratio will be 12.2245:1 with that setup.
