Compression Ratios. . .
Old Oct 18, 2004 | 06:46 PM
CircuitFG's Avatar
Default Compression Ratios. . .
Ok, i know this is a very motor specific question, and all builds cr's are not only affected by head, deck and head gaskets. . .but if i were using a 1999 Civic Si Head (resurfaced) on a B18B block, stock b18b pistons and an oem honda headgasket. . .What kind of compression ratio do you think I'm looking at? Is this figure just way too difficult to come up with a good educated guess?
Old Oct 18, 2004 | 08:01 PM
verticle's Avatar
Default Re: Compression Ratios. . . (CircuitDA9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CircuitDA9 &raquo;</TD></TR><TR><TD CLASS="quote">Is this figure just way too difficult to come up with a good educated guess? </TD></TR></TABLE>
you said it...
Old Oct 18, 2004 | 08:40 PM
4U2NV's Avatar
Check out this link... It has a compression calculator...
http://www.c-speedracing.com/h...c.php
Old Oct 18, 2004 | 09:55 PM
localmotion's Avatar
Depending on how much you cut the head (assuming .007") compression should be around 9.65:1
Old Oct 18, 2004 | 10:23 PM
CircuitFG's Avatar
I know about the c-speedracing. . .i'm just kinda sceptical of the accuracy. . .
Old Oct 19, 2004 | 05:03 AM
KilaB18C's Avatar
9.65:1 that seems alittle low, I figured it would be more than a stock B16
Old Oct 19, 2004 | 07:42 AM
verticle's Avatar
Default Re: Compression Ratios. . . (KilaB18C)
with stock b18b pistons i doubt it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by KilaB18C &raquo;</TD></TR><TR><TD CLASS="quote">9.65:1 that seems alittle low, I figured it would be more than a stock B16</TD></TR></TABLE>
Old Oct 22, 2004 | 10:38 PM
Here is the formula if you want to figure it out for yourself.
C-P+G+D+V
CR= ___________
C-P+G+D
All measurements in CC's
C= combustion chamber volume
P= piston dome volume
G= head gasket volume
D= deck height volume
V= cylinder swept volume
Techna600f4i
Jun 19, 2006 11:49 PM
B18Tahtaras
17
Jun 13, 2005 05:04 AM
mattcivic
Nov 28, 2004 04:41 PM
streetlvlhatch
Jan 22, 2004 09:55 AM
ITR_1211
Jan 18, 2004 08:09 AM
