compression test messed up ignition coil?
Old May 26, 2005 | 10:23 PM
pootie.teng's Avatar
Default compression test messed up ignition coil?
hey just wondering if i did something wrong on my compression test, cause after i did my compression test (cranking the motor with the starter) got the numbers and then when i installed everything together try to start the car and car wouldn't start. found out it was the ignition coil. replaced it and it was all good again. but the million dollar question is why did the ignition coil go bad. was it time or did i do something wrong during the test?
Old May 27, 2005 | 05:14 AM
Ketone's Avatar
Default Re: compression test messed up ignition coil? (teckno_geek)
did you remove the 15 amp fuse, or disconnect the distributor. I bet that is why you had to replace the ignition coil.
Old May 27, 2005 | 09:47 AM
dohcter g's Avatar
Default Re: compression test messed up ignition coil? (Ketone)
Never turn the engine over without unpluging the distributor during a compression test. Ignition fire needs to go to ground. It is bad for the coil not too.
Old May 27, 2005 | 08:56 PM
Default Re: compression test messed up ignition coil? (dohcter g)
thats what i forgot to do is unplug the dizy. dumb mistake. hope no one else makes this one cause it was costly to replace.
EKJOE
Jul 14, 2010 06:31 AM
SOHC_MShue
Dec 14, 2006 07:27 AM
andyt
Jan 7, 2006 10:39 PM
the.hamburglar
May 6, 2004 04:29 PM
spettinger
Dec 4, 2002 11:19 PM
