uberdata help!
i'm new to uberdata and i just download version 1.7 and opened a friends map to use on mine. for some reason when i opened the map, i get an error messaging saying "failed to assemble L1H1_AF.asm, this can cause ecu failure" does anyone know what that means? could it be that i need an older version? and also does anyone know where to download v.166 thanks
I'll leave it up for a few days, but after that I'll probably delete it.
http://portfolio.iu.edu/bchang/Uberdata1.66.zip
sounds like you're trying to open a none 1.7 map in 1.7... if so, try to import but it will be off. you need to read and just for fyi, if you are trying to run someone elses map as a basemap, your car will blow up
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BoostedSiRhc »</TD></TR><TR><TD CLASS="quote">put the bin file in the same directory where uberdata is.
see if this helps</TD></TR></TABLE>
Exactly. This was just asked the other day I think.
see if this helps</TD></TR></TABLE>Exactly. This was just asked the other day I think.
youngboiCD7
Engine Management and Tuning
Apr 12, 2018 06:13 AM
Txdragon
Mar 8, 2017 05:57 PM
