b20vtec oilpressure at idle, vtec and on
what should the oil pressure be on a b20 vtec? is a b16 oil pump good for it? let me know? thanks also what should it be at idle, when vtec hit , and passed that?? thanks alot!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PURPLETERROR »</TD></TR><TR><TD CLASS="quote">20-25 psi at idle, 75- 85 psi in the higher rpm range, oh yeah SEARCH
Don't post "search" again! I have B20VTEC too and it's very good question! We are using B20 oil pump, no problem. For about 1 year engine running. And heavy accelerated all the time.
Be care full when installing oil pressure sensor for oil pressure gouge. The B20 block material are very soft. We broke the bolt on place for oil pressure sensor. Helpfully small peace broke from block. Did some welding job, seems like every thing OK. Put in to soft cable, not directly in to block.
</TD></TR></TABLE>Don't post "search" again! I have B20VTEC too and it's very good question! We are using B20 oil pump, no problem. For about 1 year engine running. And heavy accelerated all the time.
I'll post whatever i feel like
, what year b20 bottom end are you using? It may be a good idea to upgrade to a gsr, or itr oilpump, and yes all b series honda blocks are "soft" its aluminum, use the correct adaptor and some teflon tape and you will be fine
its 2001 b20block i think.. b20z or it could be 99 i forgot.. this is for a friend.. but yea thats what i thought around 25 at idle and about 75 and up for vtec to work.. he's only getting 65 psi before vtec and it stays like that.. with the b16 oilpump
