how to remove CEL code 21?
that CERTAINLY is why u have a code 21. one wire should go to ground and one should go to a pin on ur ecu. i dont know which though but u should be able to find out.
EDIT: i just noticed ur sig. u can use almost any clip on the motor (eacv plug, air temp sensor, coolant temp sensor,) theyre all the same. just go to pick n pull pay the 2 dollar entrance fee and take a connector. its not stealing because u paid the 2 dollars.
its a 2 wire switch thing right? you can try by taking of that green part and puttin those wire things on them.. like you have on the vtec sileniod and run them straight to the ecu.. one is ground and one goes to b5
jonathan13
Apr 20, 2009 06:21 AM
