OEM oxygen sensor
Old May 26, 2005 | 07:05 PM
georgiajdm's Avatar
Default OEM oxygen sensor
-2001 oem prelude 4-wire heated primary oxygyen sensor
-32k on the 02 sensor
-50 dollars firm local buyer 60 shipped if other
I threw a CEL for slow response. I had the code cleared and the CEL never reappeared which indicates it was a intermediate failure. However, I still chose to replace it with. I just recently tested the 02 and is it is responding with no pauses. Russ can vouch that it was in working condition. You can test it yourself if you have a torch and volt-meter.
You can see that there are no deposits or any excessive carbon buildup...
tech article w/ pictures showing a bad 02 sensor...(scroll to the bottom)
http://www.ngkspark.com.au/tech_info_oxyge...nsors_index.htm
Modified by georgiajdm at 1:16 AM 5/28/2005
Old May 27, 2005 | 08:08 AM
georgiajdm's Avatar
Old May 27, 2005 | 09:15 PM
georgiajdm's Avatar
Old May 28, 2005 | 09:37 PM
georgiajdm's Avatar
Old May 29, 2005 | 07:31 PM
georgiajdm's Avatar
OogalyDoogaly
19
Apr 20, 2021 11:40 AM
g2turbo
Aug 25, 2014 07:51 AM
949
Aug 5, 2014 09:16 PM
silentblackhat
Apr 3, 2005 03:26 PM
Jet Black
Apr 28, 2004 05:30 AM
