Universal or OEM 02 sensor?
Old Apr 23, 2004 | 09:58 AM
Jet Black's Avatar
Default Universal or OEM 02 sensor?
I coudlnt find a thread relating to this in the archive....kinda surprised but anyways.
Whats the diff between using a universal 02 versus the oem unit. I mean why pay 100$ more for oem?
Is there a difference aside from ease of install?
Old Apr 23, 2004 | 10:54 AM
spaceman's Avatar
Default Re: Universal or OEM 02 sensor? (Jet Black)
good question
Old Apr 23, 2004 | 04:11 PM
Eclpze97's Avatar
Default Re: Universal or OEM 02 sensor? (spaceman)
there is really no difference other than you will always throw a CEL, and instead of having the clip in, u have to cut the clip on the engine wiring harness and twist wire it with the universal.
Old Apr 23, 2004 | 07:23 PM
Jet Black's Avatar
Default Re: Universal or OEM 02 sensor? (Eclpze97)
Explain why I'd throw a CEL??
If its just a connector I'll just solder the wires on.
Old Apr 24, 2004 | 06:31 AM
DjFreeze's Avatar
would like to know also
Old Apr 24, 2004 | 11:16 AM
91DA9's Avatar
As long as the universal is heated it shouldn't throw a CEL. You can just cut the harness off of your old O2 sensor and solder it onto the universal one.
Old Apr 25, 2004 | 11:10 AM
Jet Black's Avatar
Default Re: Universal or OEM 02 sensor? (91DA9)
Well ya and no...depends on if the original 02 sensor is heated 1st...second the CEL shouldnt be thrown as the 02 will work fine once it heats up from the exhaust right?
Old Apr 25, 2004 | 04:00 PM
Jimmy's Avatar
Global Moderator
You get what you pay for.
At least in the long run
Old Apr 26, 2004 | 03:44 PM
Jet Black's Avatar
Default Re: (Usdmdc2)
OK....but can you tell me what is different??
I dont seem to get a straight answer
Old Apr 27, 2004 | 04:27 AM
DjFreeze's Avatar
Default Re: (Jet Black)
there should be no difference i bought one and everything works great
the only thing i can think of is that you have to hard wire into the existing wires. Real easy though
Bosch universal 02
Old Apr 27, 2004 | 05:50 AM
Daemione's Avatar
Default Re: (DjFreeze)
universal 4-wire O2 sensor = OEM 4-wire O2 sensor.
Been running a universal for about 15,000 miles now, wired it up myself. Not a single problem, and only $59 from http://www.oxygensensors.com.
Old Apr 27, 2004 | 06:23 PM
Jet Black's Avatar
Default Re: (Daemione)
Woot...thats more like it guys....what did you have to do? Cut the orignal wires and solder em on?
Old Apr 27, 2004 | 06:59 PM
RABHonda's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Daemione &raquo;</TD></TR><TR><TD CLASS="quote">universal 4-wire O2 sensor = OEM 4-wire O2 sensor.</TD></TR></TABLE>\
not true. different o2 sensors have different tips that cover the platinum sensor inside of it. the vents are arranged differently, spaced out further, or could possibly face the opposite direction. the direction/location of these vents is determined by how the exhaust flows.
my $.02. i learned that in a class i took called OBD2: Taming the Beast.
Old Apr 27, 2004 | 07:22 PM
spaceman's Avatar
and if your gona solder them,use electrical solder so you dont change the resistance..im not sure about solder but sounds logical
Old Apr 28, 2004 | 04:36 AM
DjFreeze's Avatar
Default Re: (spaceman)
the bosch o2 came with a special adapter to connect the wires from the existing harness to the bosch o2. i wouldnt sodder anything, i heard it can ruin the 02 sensor
Old Apr 28, 2004 | 05:30 AM
Daemione's Avatar
Default Re: (RABHonda)
OEM (NGK) vs. universal NTK one:
The tips are a little different . . . . so what? They're both designed to measure the exact same thing, and there are countless people using them with success.
The kit from http://www.oxygensensors.com comes with all the crimp connections you need. A little dab of solder on each one & you're set to go. You'd have to be a complete cluebag to damage the sensor by soldering the wires. If you feel like spending another $100, you can get an adapter harness.
mrlondeau
May 7, 2011 03:55 PM
georgiajdm
May 29, 2005 07:31 PM
silentblackhat
Apr 3, 2005 03:26 PM
rviray
12
Oct 31, 2004 04:27 AM
