How do you measure the piston to wall clearance?
Old May 26, 2005 | 04:52 PM
siis2fast's Avatar
Default How do you measure the piston to wall clearance?
is there some big long involved process?
And what specific tool do you use?
any type of help is much appreaciated.
Old May 26, 2005 | 05:05 PM
Kendall's Avatar
Invest in some micrometers.
Old May 26, 2005 | 06:41 PM
SlowReaction's Avatar
Default Re: (Kendall)
You would use a Mic to measure the skirt of the pistons and a cylinder bore gauge to meausre the exact bore. Subtract the size of the pistons from the size of the bore and you get your pistons to wall clearance. You can find a Mic and bore gauge on ebay for pretty cheap.
Old May 26, 2005 | 08:06 PM
PURPLETERROR aka BIGMATT's Avatar
Default Re: (SlowReaction)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SlowReaction &raquo;</TD></TR><TR><TD CLASS="quote">You would use a Mic to measure the skirt of the pistons and a cylinder bore gauge to meausre the exact bore. Subtract the size of the pistons from the size of the bore and you get your pistons to wall clearance. You can find a Mic and bore gauge on ebay for pretty cheap.</TD></TR></TABLE>
ding, ding, ding, we have a winner
Old May 26, 2005 | 08:57 PM
IN VTEC's Avatar
You can also measure the piston skirt diameter and then set the dial bore gauge to zero out at that diameter and measure the difference in size between the piston skirt and the cylinder bore to give you the clearance.
For example: If you measure 3.1982" on the skirt diameter and zero out the dial bore gauge to 3.1982", the indicator on the dial bore gauge will read +.0010" for .0010" of clearance. If it reads -.0010", then you're too tight.
Some tool pics:
https://honda-tech.com/zerothread?id=1010767
https://honda-tech.com/zerothread?id=579672
I don't have any action shots for you. It's too hard for me to measure and take a picture with the camera at the same time...believe me...I've tried.
Ryhaz
15
Nov 3, 2013 06:56 PM
rich7777
10
Feb 25, 2010 11:58 AM
thollis97
Jan 22, 2007 05:22 PM
d16dcoe45
Oct 22, 2006 11:38 AM
lemongreenhatch
Sep 29, 2004 09:13 AM
