X beam vs H beam vs I beam
which is better for High rpms? to what I understand X beam (pauter) has less windage loss which makes lubrication easier at high rpm, its also very strong on the compression stroke but weaker on the intake stroke.
I dont know much about the other designs.
for all motor, I beam is the way to go, as long as your not HUGE stroke and not revving to the moon, the I beam is strong enough....
but H beams are definitely stronger rods...
i have no knowledge on the x beams....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 »</TD></TR><TR><TD CLASS="quote">for all motor, I beam is the way to go, as long as your not HUGE stroke and not revving to the moon, the I beam is strong enough....
i have no knowledge on the x beams....</TD></TR></TABLE>
If you are comparing something like this:
To something like this:
H beam is typically the weaker rod.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by visi0n »</TD></TR><TR><TD CLASS="quote">xbeam...i wouldn't pay for those.</TD></TR></TABLE>
why?
why?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote »</TD></TR><TR><TD CLASS="quote"> H beam is typically the weaker rod. </TD></TR></TABLE>
I thought it was the I beam rod the weaker, am I right??
Not completely. There are more factors than just I beam vs H beam to decide which is better. An I beam can run dual pressurized oil passages to the wrist pin in an I beam design, where as an H beam can only run a single down the middle of the rod. This design feature can make a big difference for a high rpm motor, as lubrication to the wrist pin is critical.
i beam are lighter and run dual pressurized oil passages and is better for all motor aplications..... but the 'H' beam design is stronger then the 'I' beam set up.. i believe if ur gonna run turbo or sc u would want to go with the 'H' beam.
johnzm
Jan 6, 2005 02:19 PM
