replacing del sol fuel pump
Old May 26, 2005 | 02:41 PM
93b16delsol's Avatar
Default replacing del sol fuel pump
i am assuming i will have to take out the back panels to get to it but im not sure. Could some1 please give me some info on how to do this
Old May 26, 2005 | 03:09 PM
nocturnaldragon's Avatar
Default Re: replacing del sol fuel pump (93b16delsol)
This is one of the easiest,
Take out the:
Rear most center console, (4 Screws)
Rear center under window, (Clips - Just pull it off)
Rear bin piece, (Screws)
Now see that brass colored plate? Remove that, Now replace your fuel pump.
Old May 26, 2005 | 03:36 PM
neutron91's Avatar
Default Re: replacing del sol fuel pump (nocturnaldragon)
gotta love it i hate doin fuel pumps on 88-91 civic/crx or 90-93 tegs... have to drop the damn tank
Old May 26, 2005 | 07:38 PM
evade this honda's Avatar
it took me about 45 min to do everything and put it back together(I put a walboro 3 series in)its not to hard, just make sure it doesnt leak and fumes aren leaking also
Old May 26, 2005 | 08:51 PM
AzntaggeR's Avatar
TSPeed Factory
Default Re: (d16 sol)
you do it just like this:
http://www.c-speedracing.com/h...p.php
Old May 26, 2005 | 09:49 PM
Default Re: (AzntaggeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AzntaggeR &raquo;</TD></TR><TR><TD CLASS="quote">you do it just like this:
Thats only half right, Getting to it is different in a Sol then a civic but other then that its right on.
Old May 26, 2005 | 10:20 PM
Status Sean's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nocturnaldragon &raquo;</TD></TR><TR><TD CLASS="quote">This is one of the easiest,
Take out the:
Now see that brass colored plate? Remove that, Now replace your fuel pump. </TD></TR></TABLE>
Old May 27, 2005 | 03:59 AM
dwnthehatch's Avatar
Default Re: replacing del sol fuel pump (rw92civic)
I did mine last weekend. Just remove the panels as stated above. BTW a walbro 255lph pump is a noisy bastard!
Old May 29, 2005 | 12:07 PM
so is there 3 series. as soon as i turn the key you can here it start to pump..lol
Elwuudz
Dec 8, 2006 08:34 PM
Tazragoon
Aug 23, 2006 04:21 PM
S2KBAR
Mar 22, 2005 06:43 AM
tbud454
29
Nov 23, 2004 04:12 AM
Happyman
Jul 28, 2003 04:02 PM
