ATTN: LS-turbo, 10 psi, on 450's, with uberdata, can you email me your map?
Old May 26, 2005 | 01:15 PM
pushinlsteg's Avatar
Default ATTN: LS-turbo, 10 psi, on 450's, with uberdata, can you email me your map?
I need to look at some stuff on the fuel side of the map, before I turn the boost up, thanks.
pushinlsteg@comcast.net
Old May 26, 2005 | 02:30 PM
GDM Z28's Avatar
Default Re: ATTN: LS-turbo, 10 psi, on 450's, with uberdata, can you email me your map? (pushinlsteg)
do not boost ur engine on someone else's map thats not safe...make your own base map and drive to a dyno n tune it ur self or have someone tune it
Old May 26, 2005 | 08:24 PM
wow. now all the sudden I'm using other peoples maps...?
thats not what I asked for sorry man.
I just need to look at someones fuel map. thanks.
Old May 26, 2005 | 08:50 PM
IN VTEC's Avatar
I got one you can have a look at if you've got v1.66.
This map was the final revision on a friend's car. B18B1 with SC34, JR 8" tall IC, DSM450cc/min injectors, 2.5" charge piping, 2.5" T1R exhaust - EG hatch
I only had the wideband on it to 8psi. 13 to low 14's part throttle fuel mixtures, and 11's in most of boost. It was just a rough tune, nothing on the dyno.
I'll email it to you some time tonight or tomorrow.
Old May 26, 2005 | 08:51 PM
Default Re: ATTN: LS-turbo, 10 psi, on 450's, with uberdata, can you email me your map? (IN VTEC)
thanks, I do have version 1.66
Old May 26, 2005 | 10:56 PM
used2baracer's Avatar
too bad mines is on 510's... i can tell you one thing though... when you scale for 450 and do that 120 to 130% fuel compensation for boost, you are going to have to lean out a lot off boost and add fuel in boost... thats always been my experience w/ uberdata
Old May 27, 2005 | 12:06 AM
GDM Z28's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pushinlsteg &raquo;</TD></TR><TR><TD CLASS="quote">wow. now all the sudden I'm using other peoples maps...?
I just need to look at someones fuel map. thanks.</TD></TR></TABLE>
well you said your setup...and asked for a map, there are way too many people boosting motors on other peoples maps...figured id throw u some good advice. i looked for my old 450 map but cant find it....only the 880 map
Sinner
Jun 15, 2006 09:54 AM
rorik
Jan 23, 2006 06:27 PM
alexsracing
Nov 22, 2005 01:40 PM
Pelican
Apr 8, 2004 07:55 AM
