Speedo still doesn't worked, I checked a handful of stuff already!!
Ok, my speedo doesn't work...
1) I replaced the speed sensor a while ago thinking it was that, and it still didn't work.
2) it's not the cluster since i swapped in black probe's today and it still didn't work.
3) I checked the wiring behind the cluster, and it's in A2 - Yellow/Blue, and it seemed connected fine, and didn't seem cut anywhere.
What else can I check? Any relays or something? Thanks for any help
Check the fuse...Sometimes when it wet out and i get out there and play around(like spinninig the tires and **** like that) it pops my fuse...So check ur fuse first
BUMP, and also, what would cause a speedo to read 5mph less? I just swapped mine and notice it was 5 mph slower
different sized tires/wheels can offset the speedo a little bit.....not sure if you changed those or not...
Anywho, i checked the fuse and it's fine. I found an ECU diagram and checked the wire for the speedo and it looks fine (well for as much as i can see).
What would i use to test that wire? A voltmeter?
I did a b18b1 swap in my 93 civic EX and the cluster worked with the D16z6 and after I did the swap it doesn't work with the b18. I changed the speed sensor with a new one and it still doesn't work.
So bump for ideas to help both of us out
even though you changed speed sensors, make sure the connection is good, for me, that sensor is a bitch to get clipped together.
Also, for the guy who's speedo is off, maybe you have a speedo that is set up for KMH instead of MPH, it would read somewhat off like that.
EKstasy
Jun 18, 2006 12:32 PM
ithinkitsjdm
13
Feb 23, 2005 06:17 AM
