Spedometer and Odometer problems
Old Aug 26, 2014 | 04:02 PM
Savintims's Avatar
Default Spedometer and Odometer problems
Hi guys,
I have a 95 accord lx. I just recently swapped a f23 in. When we did this we forgot the spedo was still connected and, thus, broke it. At first we had it working. Then we hit a bump and it no longer works.
We replaced the vss, and went to a junk yard and got a new cluster--still no luck.
We lifted the car and with the vss off, turned the wheels and found that the drive link is moving.
I tried to find that nice little flowchart from awardspace but its not up right now.
Any ideas?
Old Aug 26, 2014 | 06:43 PM
95accordCE6's Avatar
Default Re: Spedometer and Odometer problems
Did you check fuse number 1 in the under dash panel? Should be a 10a, when the vss was damaged it may have blown the fuse
Old Aug 26, 2014 | 07:28 PM
Savintims's Avatar
I will double check. I used a cheap fuse checker, but I found none. If this is not the reason, what else could it be?
Old Aug 26, 2014 | 07:32 PM
Other than that I would triple check the wiring, I mean you've replaced the vss and the cluster so wiring and fuses are all that are left. A loose pin is all it takes
Old Aug 26, 2014 | 07:38 PM
Savintims's Avatar
Thanks for the affirmation. I will get back to you this weekend.
Old Aug 26, 2014 | 07:44 PM
Ok good luck
Old Sep 6, 2014 | 09:54 AM
Savintims's Avatar
Is it okay if the orange wire pulses between zero and one volt. Does this implies a defective vss? The other wires seemed fine.
laocivic
13
Dec 1, 2009 05:58 PM
galvy22
Dec 30, 2008 03:39 PM
HCivicSi23
Feb 26, 2007 07:33 PM
STN_Pat
Jul 22, 2006 05:46 PM
KrispyKreme
11
Jun 2, 2006 05:29 AM
