Cleaning your engine bay
Old May 26, 2005 | 12:28 PM
Martingtrco
Guest
Posts: n/a
Default Cleaning your engine bay
Hey I was just cleaning my accord out a bit and I noticed my engine is pretty dirty. I was wondering what you could reccomend me to clean it with and what device (toothbrush wirebrush etc) Thanks alot, Chris
Old May 26, 2005 | 12:49 PM
Rad Racing's Avatar
Bart Taylor Look-alike
Default Re: Cleaning your engine bay (Martingtrco)
Cover up anything you don't want to get wet, such as air filter or distributor. Use A LOT of Simple Green on it. Let it sit for a bit. Spray some more Simple Green. Then use a pressure washer, if you don't have one a house will be ok. Unless your motor is out of your car, I wouldn't get down to the nitty dritty with a toothbrush.
Old May 26, 2005 | 03:29 PM
Martingtrco
Guest
Posts: n/a
Default Re: Cleaning your engine bay (Rad Racing)
heh power washing makes me a bit nervous but sounds like a good plan
Old May 26, 2005 | 04:25 PM
SPEED FoRCE's Avatar
engine brite works pretty good
Old May 26, 2005 | 04:28 PM
sj993's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rad Racing &raquo;</TD></TR><TR><TD CLASS="quote">Cover up anything you don't want to get wet, such as air filter or distributor. Use A LOT of Simple Green on it. Let it sit for a bit. Spray some more Simple Green. Then use a pressure washer, if you don't have one a house will be ok. Unless your motor is out of your car, I wouldn't get down to the nitty dritty with a toothbrush.</TD></TR></TABLE>
Simple Green + Pressure washer
Old May 26, 2005 | 05:08 PM
i20ar's Avatar
Default Re: Cleaning your engine bay (sj993)
when i clean m engine bay i take it to the local self carwash place... tie plastic baggs around any electrical component then i blas the engine with auto degreaser then wash it down with the high pressure .. just make shure you cover all your electronics
Old May 26, 2005 | 05:31 PM
The_Todd's Avatar
Farts in the shower
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sj993 &raquo;</TD></TR><TR><TD CLASS="quote">
Simple Green + Pressure washer </TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DJ14aZnS &raquo;</TD></TR><TR><TD CLASS="quote">when i clean m engine bay i take it to the local self carwash place... tie plastic baggs around any electrical component then i blas the engine with auto degreaser then wash it down with the high pressure .. just make shure you cover all your electronics</TD></TR></TABLE>
Just be careful with washing a hot engine bay .
Old May 26, 2005 | 06:37 PM
speedzone's Avatar
Default Re: Cleaning your engine bay (.ken)
Gasoline, wire brush, sandpaper, Drain-o. Not.
Old May 26, 2005 | 06:45 PM
i20ar's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .ken &raquo;</TD></TR><TR><TD CLASS="quote"> :
Just be careful with washing a hot engine bay .</TD></TR></TABLE>
YES!!!!!!!! I ALMOST FORGOT LET IT COOL ... you dont want anything to go and crack on you.. hot things + instant cold = Broken/cracked/warped stuff.. be carful buddy!
Old May 26, 2005 | 06:51 PM
deserthonda's Avatar
like most people say use any degreaser, hot pressure water works best if not i have cleaned a bunch with water hose after sraying down with degeaser make extra sure engine is turned OFF....in some cars i have seen some water go into the plug hiles so you might want to remove wires and make sure there is no water in plug holes or car will missfire
Old May 27, 2005 | 07:46 PM
speedzone's Avatar
I used Simple Green sprayed on a slightly warm engine and surrounding parts. Let it sit for a good 5 minutes or more. Spray on some more and use a brush that isn't too stiff to scrub with. Hose it off gently and see what areas need more work. Spray them generously and let the stuff soak for a good 10 minutes. Be patient.
My under hood area looks real good after cleaning it as I just described.
IBriaIN
Feb 3, 2011 12:27 AM
qeldrom
Jul 22, 2008 06:58 AM
RideOrDie
May 21, 2005 03:54 PM
Spoonie Luv
May 2, 2003 03:26 PM
95hybridcivic
Jul 10, 2002 06:34 PM
