My Shitheap keeps burning out Rotor Arms!
Old May 26, 2005 | 11:46 AM
S88HON's Avatar
Default My Shitheap keeps burning out Rotor Arms!
Help! This car is Mase tuned and running sweet until I started getting tach jump. Changed over the ignitor and its all hunky dorey. Thing is.. when changing the ignitor I used a brand new OEM rotor arm to replace the slightly suspiciously 'fried' one (one leading edge is pitch black and also the plastic is slighty melted). 1 week of happy driving, its now its created a slight misfire under high rpm (8k onwards WOT) but part throttle it seems to be ok?! .. I took the cap off and saw the arm again black on 1 side and heavily scorched..
My ignition setup is MSD Digital 6 with external coil, MSD cap, Magnecor leads (8.5mm) with NGK BCPR7ES gapped to Mase specs (0.026)
Please help! I'm running outta money buying rotor arms ! (or could it be a more sinister problem?) Its definately got us stump over here...
Thanks in advance.
Old May 26, 2005 | 02:56 PM
S88HON's Avatar
Default Re: My Shitheap keeps burning out Rotor Arms! (S88HON)
Nobody??????
Bump anyway *sigh*
Old May 26, 2005 | 02:58 PM
Mase's Avatar
try removing the aftermarket ignition and run stock ignition altogether.
that msd could be taking a **** and screwing everything up
Old May 26, 2005 | 03:16 PM
Sketch_hs's Avatar
New OEM dizzy!
Old May 26, 2005 | 03:30 PM
S88HON's Avatar
Default Re: (Sketch_hs)
What makes you say that?????
Old May 26, 2005 | 03:41 PM
xci_ed6's Avatar
Default Re: My Shitheap keeps burning out Rotor Arms! (Mase)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mase &raquo;</TD></TR><TR><TD CLASS="quote">try removing the aftermarket ignition and run stock ignition altogether.
that msd could be taking a **** and screwing everything up</TD></TR></TABLE>
agreed. That or your just running too much amperage through the ignition system. Removing the MSD will also cure that.
Old May 26, 2005 | 04:08 PM
tony1's Avatar
MSD's don't go bad, do they?
Old May 26, 2005 | 06:09 PM
non-VTEC's Avatar
Default Re: My Shitheap keeps burning out Rotor Arms! (tony1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tony1 &raquo;</TD></TR><TR><TD CLASS="quote">MSD's don't go bad, do they?</TD></TR></TABLE>
is that sarcasm?
Old May 26, 2005 | 07:02 PM
tonydatyga's Avatar
I don't think it is
Old May 26, 2005 | 08:25 PM
MaxBoost's Avatar
New User
Default Re: (tonydatyga)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tonydatyga &raquo;</TD></TR><TR><TD CLASS="quote">I don't think it is</TD></TR></TABLE>
I think it is.
I've had several MSD's fry on me. No reason to use MSD unless you need it, when you start having high horsepower ignition issues, then fine.
Old May 26, 2005 | 09:19 PM
Mase's Avatar
yes tony is being sarcastic, msd's take a **** quite often.
hey albert, give me a ring, im coming back down south soon.
Old May 26, 2005 | 09:34 PM
turbo*s2k's Avatar
check the teeth looking things on the inside of your distributor cap. One might be bent, and nicking your rotor as it rotates and ******* it up.
I had the screw back out of my rotor, and shoot right out of my distributor cap. Who's knows how long I was running it that way. I noticed that it bent one of the teeth looking things on the inside of the cap and my rotor looked a little beat up... Just something to look at.
Good luck!
mightyjoecivic
11
Jul 13, 2022 08:04 PM
PINKIE2
Jan 15, 2014 08:00 PM
1sikhatch
Apr 26, 2010 02:35 PM
Dubs13
Apr 26, 2010 02:24 PM
biotech0123
Sep 6, 2006 07:35 AM
