just want to make sure i am doing this right . . .
Old May 25, 2005 | 07:50 PM
hatchblack's Avatar
Default just want to make sure i am doing this right . . .
i have a z6 motor in my 89 si and i am building up the spare z6 that i have to put a turbo on it. I dont' plan on running lots of boost as this is also a daily driver. I will be doing lots of work to this motor and plan on trying to get around 200hp out of it at least at the crank. So, with that in mind, will the stock z6 injectors be strong enough at the 240cc's or should i put bigger injectors in it? if i go with the prelude 345cc injectors, which i guess are peak and hold, i need a resistor box? does that mean that i need to hook up the resistor box that i originally had in my civic for the 89 si motor that i took out to run the obdI injectors? Also, one more question - am i going to need any kind of turbo management system or injector management system if i am running the low boost, or if i switch to the bigger injectors? As you can probably guess, turbo is not that familiar with me. I am used to going NA, so I just want to make sure i have it right before i go and buy everything and try to hook it up. thanks in advance guys.
b18 hatch mike
Oct 5, 2010 05:59 PM
lovey408
Sep 19, 2007 12:45 PM
iBrandon
Jan 29, 2006 02:12 AM
halfpint
Jul 8, 2003 12:17 PM
