turbo piggyback and stock MAP woes....
Old May 25, 2005 | 03:11 PM
AngelTeg's Avatar
Default turbo piggyback and stock MAP woes....
Planning on going turbo with a e-manage with injector and ignition harness as my engine management. my question is what do I need for a stock MAP sensor to work???
I did a bunch of searches, can't quite figure it out because some people say that the ECU will flat out not interprate the boost signal from the MAP. Other say that the MAP will go to about 11 psi...
Do I need a missing link and all will work fine?
-Mike
Old May 25, 2005 | 03:12 PM
dustin's Avatar
Default Re: turbo piggyback and stock MAP woes.... (AngelTeg)
Doesn't the emanage have its own MAP sensor?
The stocker goes to 11psi but the ECU will throw a CEL if it sees >= 3v from the sensor (around 0.5psi).
If you want to run a piggyback you have to use a missing link...
B16Civic93
Apr 2, 2005 09:39 AM
BluntMan
Mar 4, 2004 07:05 AM
dominate9
Nov 15, 2003 01:01 PM
h22acclude
Oct 23, 2003 02:48 PM
Turbo EG6
Aug 19, 2001 05:04 PM
