Turbo HP?
Old May 25, 2005 | 03:05 PM
JustinL's Avatar
Default Turbo HP?
When buying a turbo, should the hp rating be more than the hp i want to make total, or just the hp i want to make with the turbo? i.e. if i want 300 hp with turbo and a 50-100 shot of nitrous, should i get a 400+ turbo or a 300-350 turbo?
Old May 25, 2005 | 03:39 PM
B00STED Si's Avatar
Default Re: Turbo HP? (pyro_assassin)
400+ turbo, b/c the hp rating that the companies use to label their turbochargers are pretty much the highest amount of hp you'll see with it. A lot has to do with the efficiency, if you buy a larger turbo, and want to make 400hp, youll make it at lower boost and lower temps rather than having a smaller turbo at 25lbs of boost putting out tremendous stress and temperatures on your motor.... thats exactly what im doing right now, i swapped out my SC50 that i made 310 on at 13lbs, for an SC61, hoping to make around 400hp at 16 lbs or so...
Old May 25, 2005 | 05:13 PM
Zakar's Avatar
there is alot more to it then that.. you need to size the turbo for the application.. there are alot of factors when choosing a turbo.. is it a daily driver or a strip only car? engine displacement? desired power level?
post your current setup info so we know what you have to work with..
Old May 25, 2005 | 06:17 PM
JustinL's Avatar
Default Re: (Zakar)
it will be a daily driver for now, but im working on getting a new daily driver to park the honda. Im looking to get a new turbo and manifold for now, but later i plan on ported and polished vtec head swap, intake manifold and tb, i/c piping, bigger injectors, hondata, and a secondary fuel system for n2o with a direct port.
as it sits, i have sohc non-vtec stock rebuilt head, 310cc rc injectors, aem fuel rail, b&m pressure regulator, je pistons, eagle rods, balanced and knife edged crank, clevite bearings, smc alcohol injection, greddy turbo kit, intercooler(forgot what kind), custom getto i/c pipe, and type s bov. Im running e manage and eo1 for fuel management. id like to see what kind of power a sohc can make on turbo alone, then add n2o to help spool time and add a little power after i get rid of the alcohol.
dk-fabrications
Oct 17, 2004 12:04 AM
Briman2021
Oct 28, 2003 08:34 AM
Papa G
18
Apr 2, 2002 04:11 PM
