MINI-ME SWAP need help
Old May 25, 2005 | 02:20 PM
91backslash's Avatar
Default MINI-ME SWAP need help
i have a 91 crx si with my original block but i haev ZC pistons overbored .010 and rods i have 96 Y8 VTECH head ported and polished the set up is known as the mini-me swap. vtech kicks in at 3800 and i also have a t3 super 60 turbo with intercooler. my governor is set at 7,000 RPM's how can i remove this , new ecu? also i was wondering if anyone knew what redline is for this??? please help
Old May 25, 2005 | 03:22 PM
Redline130's Avatar
Default Re: MINI-ME SWAP need help (91backslash)
What ecu are you using? Also, why do you need to rev higher than 7K rpm?
Old May 25, 2005 | 04:06 PM
i believe it is the stock ecu with OBD0 and i was wondering about the revlimiter because if it is higher than 7000 i wanted to know whether i could and if i should. thanks
Old May 25, 2005 | 04:45 PM
Redline130's Avatar
How are you controlling VTEC activation? The only reason you should need to rev higher than 7K, is if you are making power that high in the revs.
Old May 26, 2005 | 08:39 PM
there is a v-tech rpm switch controller and there are different switches that i can use to tell it when to kick in i have it set to kick in at 3800 rpm's now
Old May 26, 2005 | 08:58 PM
wdwalker's Avatar
Default Re: MINI-ME SWAP need help (Redline130)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline130 &raquo;</TD></TR><TR><TD CLASS="quote">VTEC</TD></TR></TABLE>
you've now spelled it wrong twice, in two different ways.
http://www.pgmfi.org
you're looking for turboedit. i'm chipping a buddies ls/vtec crx with it this weekend. its the obd0 solution to uberdata (which i personally endorse wholeheartedly)
3800 is too early imo, i'm guessing you're bogging at the vtec engagement point, this would be why. and unless you have a bigger cam, you won't make power past 7k anyway, its pointless to rev higher than this.
96Hatchy0
Nov 26, 2010 12:28 PM
my Efin SI
May 31, 2010 06:05 PM
hECtUbiS
Sep 11, 2004 11:06 AM
Cozmo85
Aug 27, 2004 12:04 PM
