No timing mark on pulley - How do I Set Timing???
Old May 25, 2005 | 11:10 AM
baphomet's Avatar
Default No timing mark on pulley - How do I Set Timing???
Modified by devnull at 8:39 PM 6/1/2005
Old May 25, 2005 | 06:33 PM
T4eg's Avatar
Default Re: No timing mark on pulley - How do I Set Timing??? (devnull)
if u pull the pulley off its got a keyway on the crank and a mark on the oil pump. Just line them up
Old May 25, 2005 | 08:33 PM
SOHCmaster's Avatar
Yeah what he said, Then get some white out and mark your pully so you can see it w/timing light
Old May 27, 2005 | 09:40 AM
baphomet's Avatar
Default Re: (PK SPEED)
I can't get the pulley off (I need to take it to a shop - damn bolt) I just need to set ignition timing for emmisions.
The keyway marks 16 deg btdc (which is what I need to set it at) or tdc?
Old May 27, 2005 | 07:01 PM
baphomet's Avatar
There is probably something I don't get
Old May 29, 2005 | 04:27 PM
baphomet's Avatar
Help
Old May 30, 2005 | 05:33 AM
baphomet's Avatar
Old May 30, 2005 | 05:59 AM
IN VTEC's Avatar
Use a dial-back timing light with the pointer on the lower timing belt cover to find 16 deg BTDC.
Old May 30, 2005 | 07:01 AM
B16CRXT's Avatar
I would think that if the pulleys are the exact same diameter, then they would be the same degree by a protractor. Good Luck
Old May 31, 2005 | 10:46 AM
tgreaves's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by devnull &raquo;</TD></TR><TR><TD CLASS="quote">What if I use a protractor and measure an oem pulley and transfer the 16 deg.mark to the pulley that is on there. I am pretty sure the mark on there is tdc but I will confirm before I try this. </TD></TR></TABLE>
Now theres something that I have never heard before.. Sounds like it would work fine.. Kinda strange why you dont have a timing mark on your pulley..
Old May 31, 2005 | 12:52 PM
baphomet's Avatar
Default Re: No timing mark on pulley - How do I Set Timing??? (tgreaves)
I don't think its strange. There are a lot of shady scammers in the import scene and its just my luck that I have to keep running in to them....
luvmihatch
Jan 9, 2008 01:25 PM
projectTeG
Mar 31, 2005 05:17 PM
IggDawg
Mar 13, 2004 03:27 PM
powerfulperformance
Oct 20, 2003 04:58 AM
OBD-One-Kanobe
Nov 1, 2002 09:21 AM
