Greddy Oil Sandwich Plate
Ive seen a lot of people using the GReddy Oil filter sandwich Plate and it looks like a respectible priced product. where is the best place online to get these. i got a b18a LSVT
will the ac auto technic version work too, i saw it on the site. it look like it had 4 1/8" holes so i dont know if that can feed a 6an line or not going to the head for vtec. im sure it will be fine for the turbo line though. what about greddys, what size holes are in it.
i am gonna use it on my ls vtec setup, one of the 1/8" holes im gonna put a 1/8 to -6an adapter in one and run it to my head and the other hole im gonna put my turbo line in it. anyone used one on an ls vtec kit? i heard i have to use a different oil filter with it, ????
I think that's only with the filter relocation kits. If you have to switch filters, use Nissan or Toyota 3/4"x16tpi filters.
If you're going to spend $50 to $60 for a LSVTEC feed adapter plate, then I'd spend the extra money for a GE adapter plate instead.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC »</TD></TR><TR><TD CLASS="quote">I think that's only with the filter relocation kits. If you have to switch filters, use Nissan or Toyota 3/4"x16tpi filters.
If you're going to spend $50 to $60 for a LSVTEC feed adapter plate, then I'd spend the extra money for a GE adapter plate instead.</TD></TR></TABLE>
i went with the greddy kit, it utilizes STOCK FILTER for those who think you have to have a gimp corolla filter. and it has a larger threaded hole im using the the 6an head feed for vtec.
