greddy oil filter adapter
i have a c1 motor in a 95 dx
i picked up the greddy filter adapter to give blood to my snail
the damn thing its tight, yes i know how to install it, used both gaskets, just to make sure, and the thing leaks
not pissing out... just a moderate drop... not from the line or the filter its coming from behind the adapter... im getting so fed up
i may get a adapter to the oil pressure and secure it somewhere on the firewall and re-route it there....
help.... b4 i take c4
Re: greddy oil filter adapter (Gsr_Hybrid_theory)
I've also had mine for a while with no problems. Check your surfaces are clear of debree. Also be sure to tighten the thread extender.
Re: greddy oil filter adapter (rioninja)
thats why they stopped making them cause they had to many problems I have friends that have had good luck with them but then ones that have had bad luck
Re: greddy oil filter adapter (Lmgrcivic)
Ive installed 4 or 5 of them. Mine was the only one that leaked so I pulled it off, cleaned it well and reinstalled with a thin coat of RTV. let it set for a 1/2 hour (warm motor to help cure fast) and it has lasted for 30k miles now. I wonder why they leak, the design is so simple, just a groove and an O ring...
Re: greddy oil filter adapter (Bailhatch)
yep, it was clean, i re did it at work 1 nite, took it apart, cleaned it, hondabonded the exterior surface, lubed up both rings and put it back
it was better BUT not fully gone.... i dunno, crap
hondalovinEK9
08-24-2007 06:00 AM
Tsurara
12-02-2004 08:02 AM
