Anyone remember the booted wheel issue? this is my version... only it involves an axle and a hub
Old May 24, 2005 | 08:20 PM
Bay_707's Avatar
Default Anyone remember the booted wheel issue? this is my version... only it involves an axle and a hub
I can't get the axle out! its ******* seized or something.... Anyone know how to get it out? (tried impact hammer about 8 different various sized mallets hammers etc)... also my old 4 lug is for sale... if you want this axle its extra .
Old May 24, 2005 | 09:18 PM
morepoop4u's Avatar
Default Re: Anyone remember the booted wheel issue? this is my version... only it involves an axle and a hub
you could try this
http://autozone.com/servlet/Ui...d.jsp
Old May 24, 2005 | 10:18 PM
Bay_707's Avatar
lol never though about that : )
Old May 24, 2005 | 10:19 PM
ej0513's Avatar
wtf mike... that suckss..
Old May 25, 2005 | 03:12 PM
Bay_707's Avatar
up
Old May 25, 2005 | 03:28 PM
97tegGS's Avatar
torch man. Heat is your friend.
It might be a little more difficult since that end it flared but worth a shot
Old May 25, 2005 | 03:46 PM
skunked's Avatar
Default Re: (97tegGS)
Soak it with some liquid wrench for atleast a few hours.
Old May 28, 2005 | 12:43 AM
Bay_707's Avatar
ill just file the end of the axle prob tommorow and play with it a little more
Old May 28, 2005 | 06:25 AM
dFreezy's Avatar
Default Re: (Bay_707)
wd40 isn't that great for removing stubborn joints/nuts/bolts/etc...i prefer pb blaster
Old May 28, 2005 | 06:44 AM
wedgenix's Avatar
Default Re: (dFreezy)
I second the PB Blaster motion....that stuff worked wonders on all kinds of rusted up junk on an old pickup I bought....even when the 1/2" impact cranked up to 140psi + wd40 wouldn't work after 2 days of trying. Soaked it w/ PB and 5 mins later the impact broke it free on the first try (had 4 lugnuts, 2 bumper bolts, lower shock mount, caliper bolt, and 4 caliper pins that held the pads in all fused together, wd40 failed on all of them, PB Blaster worked on all of them...PB r0x0rz) All I use WD40 for now is to make squeaky closet doors quiet.
Old May 28, 2005 | 06:56 AM
Arsenal's Avatar
Default Re: (wedgenix)
Had the same problem, just put it on a press and you;'' be fine!
Old May 28, 2005 | 08:02 AM
LSvtec03's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by morepoop4u &raquo;</TD></TR><TR><TD CLASS="quote">you could try this
http://autozone.com/servlet/Ui...d.jsp</TD></TR></TABLE>
Old May 28, 2005 | 10:16 AM
TA Performance's Avatar
i htink u might have mushroomed the end of the axel. is it illegal to remove the boot from your car?
Old May 28, 2005 | 02:08 PM
StrictlyJdm94's Avatar
heat it up with a blow tourch thats wut i did with mine when i took mine out
1990IntegraLS
Suspension & Brakes
May 19, 2018 01:09 PM
captain_crunch
Suspension & Brakes
Jul 26, 2008 06:40 PM
honda_conversion
Jun 5, 2007 11:17 PM
honda_conversion
Jun 5, 2007 03:10 AM
4doorH22
Jul 23, 2002 07:55 PM
