axle wont go in to the hub
the axle will not go in to the passanger side hub should i heat up the axle n try 2 slip it in or keep on bangin the hub untill it goes
Re: axle wont go in to the hub (honda_conversion)
How about lubricating it like your supposed to instead of beating the hell out of your poor axle and hub its not a tight fit they should fit or you have a wrong axle/hub.
Just take your time and make sure you warp the teeth on the shaft. No need to heat up the metal it just makes it expand and get bigger. Also make sure you have the right axle.
Sol to Sol
Is it in the transmission all the way? If so, then you have to pull the knuckle waaaaay out, and stick it in. I used my knees for that, but if you have a friend, it would be a lot easier
Once the splines are in the hub, tap it in with a rubber mallet.
And you don't have to lube the axle to the hub, you don't want those parts moving agent each other. lol
Re: axle wont go in to the hub (bblevinsJDM...)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JarvisW »</TD></TR><TR><TD CLASS="quote">And you don't have to lube the axle to the hub, you don't want those parts moving agent each other. lol</TD></TR></TABLE>
Um I think you are wrong, you should definitely lube the axle shaft!
Sol to Sol
Re: axle wont go in to the hub (mikeycivic)
Well, yeah, but only need a light coat, and its really only to assist with the install, the one that needs grease is the one to the transmission, that is important.
So, nevermind lol. I'll go to bed now
HondaCivic666
06-05-2018 10:25 PM
