Type-R pistons on stock GSR rods??
i got my motor rebuilt but now im kina regretting i went a lil cheap, rebuilt a gsr motor type-r pistons,type-r cams,sknk 2 gears,sknk 2 IM,springs retainers n 3 angle valve job. The whole deal with tha rebuild is i was aiming for at least 9k rpm but now im having second thoughts bout hittin that high because of tha stock rods.
So some input on what may happen and if anyone would know tha compression?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mayndonttripp »</TD></TR><TR><TD CLASS="quote">i was aiming for at least 9k rpm</TD></TR></TABLE>
Why?
Why not just aim for a power goal and rev to wherever it makes power as apposed to where it sounds cool
Chances are, with ITR cams and a fairly stock head it wont really be making much power after 8300'ish anyway...
Why?
yeah i know tha itr cams wont make power at that rpm im planning to swap it out after break in with stage 1 sknk 2 cams hah shoulda put that in tha begining, but now still not shure if i wanna do that with tha chance of bending a rod
and another question is there a difference between the Type-R rods and GSR rods?
I agree with everyone on this when they say rev to where you make power....no use going that high if your not making any power up to 9k...
the bolts should have been replaced with ARP rod bolts atleast. You can still do this if the enigne is not in the car yet......you can still do it even if it is but its a little harder to do from under the car.
"your rods will be fine till 9k..
but for a lil cash you can pick up some itr rods which are lighter/stronger."
your question has already been answered.
jdmjeff
Feb 14, 2005 01:16 PM
