strange problem, car died while driving then refused to start.
Old May 23, 2005 | 03:02 PM
LostCRX's Avatar
Default strange problem, car died while driving then refused to start.
I'm encountering a very strange problem. I was drivingmy turbo b18 crx on an Interstate last night, doing 75 on 5th gear. All the suddenly the engine just shut down. I pulled over onto the shoulder and attempted to find my problem.
-Main relay did make two clicks, pump does prime but the CEL doesn't go off after second click.
-Battery is relocated to the rear, ground on thermostat is good, there is a ground on tranmission, two more ground on the motor. All connection are retightened.
-Battery has good power, even tried jump start.
-There is spark, rotor and cap have been checked. New set of plugs have also been installed.
YET the car will crank but refused to start. There is no prior symptoms, the car was runnning great, it also ran really great during my autocross in the morning. Please help me out.
Old May 23, 2005 | 03:12 PM
Chiovnidca's Avatar
Default Re: strange problem, car died while driving then refused to start. (LostCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LostCRX &raquo;</TD></TR><TR><TD CLASS="quote"> the CEL doesn't go off after second click.
Does it have a code stored? Have you checked your fuses?
NikoZai's Avatar
check compression, check fuel injectors are firing, check fuel pressure.
Old May 23, 2005 | 03:13 PM
C-RICKS's Avatar
Kind of happenned to me..
Did you by chance make sure that the rotor screw was tight and in place.
It took me till 1:00 am one night before i finally gave up and called the auto club to tow me home.
The next morning, after carefully inspecting my car, my mechanic told me my rotor screw came loose.
Old May 24, 2005 | 03:05 PM
LostCRX's Avatar
Default Re: strange problem, car died while driving then refused to start. (C-RICKS)
problem solved.
It was my distributor locking up. It locked up so bad that we couldn't even turn it using channel locks, there was also metal shaving inside the distributor. That explains why the car won't turn over.
thanks everybody for the help.
Old May 26, 2005 | 11:14 AM
LostCRX's Avatar
Update: This suck!
I bit the bullet and bought a new distributor, yet the car will crank but will not start.
Fuel was check by taking out a line at the filter while cracking, fuel come spewing out.
Every spark was checked, there was good spark and these plugs are brand new.
Compression was checked, not perfect but sitll has decent compression.
The car does crank, fuel pump does prime and i got fuel, but it still won't help. Any other idea guys?
Old May 26, 2005 | 11:56 AM
juice91si's Avatar
timing?
Old May 26, 2005 | 01:30 PM
Chiovnidca's Avatar
Flooded?
Old May 26, 2005 | 03:59 PM
Kwicko's Avatar
Default Re: strange problem, car died while driving then refused to start. (Chiovnidca)
I'd check the timing and the timing belt. If the distributor locked up that hard, it's possible that the cam gear may have sheared some teeth off the t-belt. Happened on my '91 Accord.
Try having someone turn it over while you look in the oil filler on the valve cover to see if the cams are turning - that's if you still have the upper timing belt cover on, and can't readily see if the belt is turning or not.
Mike
Old May 27, 2005 | 07:17 AM
LostCRX's Avatar
Default Re: strange problem, car died while driving then refused to start. (Kwicko)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kwicko &raquo;</TD></TR><TR><TD CLASS="quote">I'd check the timing and the timing belt. If the distributor locked up that hard, it's possible that the cam gear may have sheared some teeth off the t-belt. Happened on my '91 Accord.
Mike</TD></TR></TABLE>
You are right. The dist locked up so hard that the belt jumped several teeth. Luckily i was only cruising aroung 3-4k rpm. I got every lined up right, crank at 0btc, arrows on cams are both up, the mark on the cams line up with each other, but it still idle really bad and backfire like **** if i try to give a little gas. Any other ideas?
Old May 27, 2005 | 01:21 PM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LostCRX &raquo;</TD></TR><TR><TD CLASS="quote">You are right. The dist locked up so hard that the belt jumped several teeth. Luckily i was only cruising aroung 3-4k rpm. I got every lined up right, crank at 0btc, arrows on cams are both up, the mark on the cams line up with each other, but it still idle really bad and backfire like **** if i try to give a little gas. Any other ideas?</TD></TR></TABLE>
Compresion and leakdown tests? Could have bent a valve or more.
Old Jun 3, 2005 | 08:47 AM
LostCRX's Avatar
I miss my car. It's been almost two weeks.
I have 155-160 compression in all cylinder. That only confuses me more.
Old Jun 7, 2005 | 08:18 AM
rexfrumthagrave's Avatar
same with my rex... driving rmmmmmmmmmmmmmm then engine cut out..
i hope its ok but i blew a motor like this b for
cuz i threw it into 1st going 50 or so trying to get it started again
Old Jun 7, 2005 | 08:19 AM
rex back to tha grave...
Old Jun 21, 2005 | 07:17 PM
lodo1's Avatar
Default Re: (rexfrumthagrave)
its fixed, tell them homie
tran1088
Acura TSX
Jan 19, 2012 11:51 AM
k_vd16
Feb 5, 2011 01:42 PM
kyorishin
Jul 14, 2006 08:11 AM
Tee Jay
11
Oct 26, 2005 03:16 PM
Elemental
Sep 7, 2004 02:08 PM
