'91 Civic Shift Points...
Old May 22, 2005 | 09:45 PM
deanh8's Avatar
Default '91 Civic Shift Points...
Whats up, Im trying to figure out some good shift points for a basicaly stock '91 Hatch. Its the slow std. 1.5l with the 4-speed
But since it dosnt have a tach, could you guys tell me what MPH it is best to shift at for max. performance (if you can call it that) thanks.
Old May 22, 2005 | 09:51 PM
mr-mister's Avatar
Default Re: '91 Civic Shift Points... (deanh8)
Let it bounce off the rev limiter a few times and you can find out for yourself. Its been so long since ive seen a 4 speeder, those were the days tho baaaaaaaaaaaaaaaaaaaaaaaa- boooooog
Old May 22, 2005 | 11:00 PM
FalkenSiR's Avatar
Default Re: '91 Civic Shift Points... (mr-mister)
35-60-80?? 120 ? (no rev limiter so im afraid since i have no tach)
Old May 22, 2005 | 11:15 PM
31flavorscivic's Avatar
Default Re: '91 Civic Shift Points... (fast88std)
back when i had my 70 HP cx engine combined with the std 4spd tranny, my shift points were 30-55-75-nevergotthathigh. There is nothing to be had with 70 HP. The best thing to ever happen to me was right after i got my civic running with the 130 HP engine and actually getting to feel something called high end torque. It was new to me.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast88std &raquo;</TD></TR><TR><TD CLASS="quote">35-60-80?? 120 ? (no rev limiter so im afraid since i have no tach)</TD></TR></TABLE>
did you remove your limiter? the absence of a tach just means that you don't know what RPM you are at. The car still knows.
edit- you prolly already know that don't ya my bad...
Old May 24, 2005 | 06:48 AM
Floored's Avatar
Open up the manual and it tells you the max shift points. which i think are 30, 55, 96, .... I just installed an si cluster on my std and 30 mph in 1st is about 6k, after second gear though the car is pretty much useless... I cant wait to get mpfi and install my cam, and dump that worthless 4spd tranny
Old May 30, 2005 | 08:38 PM
randy_luna's Avatar
I have a 90 si, my shift point is around 7200-7300 rpm's. In 3rd gear, i'm about 95mph before i red line. To be sure i'll take a few passes in 1st and 2nd to be sure and will pass them on.
Old May 30, 2005 | 10:35 PM
d15civ's Avatar
Default Re: '91 Civic Shift Points... (randy_luna)
mine are around 7300-7400
2nd-65
3rd-110
4th-159
5th-never gone fast enough
all in Km/H of course.
EDIT:::I need to learn how to read, he wanted std shift points
Old Sep 22, 2005 | 08:26 PM
deanh8's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mr-mister &raquo;</TD></TR><TR><TD CLASS="quote">Let it bounce off the rev limiter a few times and you can find out for yourself. Its been so long since ive seen a 4 speeder, those were the days tho baaaaaaaaaaaaaaaaaaaaaaaa- boooooog</TD></TR></TABLE>
Sorry to bring this post back up. But I was wondering if there even was a rev limiter??
Is there a rev limiter on a std hatchback, I want to take it up high one day to see where its set at, but I dont want to blow it up if there isnt.
Old Oct 27, 2005 | 11:35 PM
deanh8's Avatar
bump..
Old Oct 29, 2005 | 12:31 AM
richmedic's Avatar
i had a 91 civic si but since yours is a 4 speed im sure its geared different. rev it till it roars? or meows whateva
Fastwhip
Feb 12, 2008 10:18 PM
bgraiders323
Jul 23, 2005 08:14 PM
SleepnCiViC
Dec 8, 2003 07:34 AM
95civicracer
18
Feb 19, 2003 06:34 PM
