Where's the drain plug for the radiator?
Old May 22, 2005 | 05:30 PM
ALMXDUPINTEGRA's Avatar
Default Where's the drain plug for the radiator?
Old May 22, 2005 | 05:41 PM
Ketone's Avatar
Default Re: Where's the drain plug for the radiator? (ALMXDUPINTEGRA)
you can not miss it. from looking under the car it is on the right hand side of the radiator. It is white and almost looks like a wing nut.
Old May 22, 2005 | 07:53 PM
Deluzional's Avatar
Default Re: Where's the drain plug for the radiator? (Ketone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ketone &raquo;</TD></TR><TR><TD CLASS="quote">you can not miss it. from looking under the car it is on the right hand side of the radiator. It is white and almost looks like a wing nut.</TD></TR></TABLE>
actually left hand side if youre facing teh car
Old May 22, 2005 | 09:32 PM
dvp's Avatar
dvp
You've got to be either lazy or joking. Maybe you should get under the car and look. Its right there.
Old May 22, 2005 | 10:50 PM
Default Re: Where's the drain plug for the radiator? (dvp)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dvp &raquo;</TD></TR><TR><TD CLASS="quote">You've got to be either lazy or joking. Maybe you should get under the car and look. Its right there. </TD></TR></TABLE>
Thanks for your help it was so helpful.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Deluzional &raquo;</TD></TR><TR><TD CLASS="quote">
actually left hand side if youre facing teh car</TD></TR></TABLE>
Thanks
Old May 25, 2005 | 07:56 AM
actually looking down the left side I didn't see it. By getting under the car..right at the splash guard there is a little opening and the drain plug is right there.
Old May 25, 2005 | 08:10 AM
97tegGS's Avatar
Old May 25, 2005 | 08:12 AM
good diagram
Old May 25, 2005 | 08:15 AM
Dc2 Powered's Avatar
lol jesus.. i answered this question a month ago with pictures of my own raditator and all..
and having a n00b clown on you hahahahahhahaha
goodluck with whatever your trying to do.. probaby flush system
Old May 25, 2005 | 08:18 AM
97tegGS's Avatar
Default Re: (Dc2 Powered)
Some people aren't mechanically inclined as others. Never hurts to ask. OR search but He found his answer.
Old May 25, 2005 | 08:24 AM
purplegsr's Avatar
Default Re: (97tegGS)
Remember to drain the block too, there is quite a bit of coolant in there. It is a big *** bolt (19mm, I think) on the block directly behind your header, if you have a stock manifold you will have to remove the heat shield to get to it, but no flush/coolant change is complete without it.
G2_Fella
May 3, 2008 06:50 PM
b16a4
Sep 5, 2007 05:14 PM
mysicivic1991
Apr 19, 2007 10:57 AM
EnKidu
Oct 23, 2004 07:54 PM
JKS2000
Honda S2000
Aug 28, 2004 02:26 PM
