Si Cluster Problem ????
i just installed a 99 civic si cluster in my 93 civic cx hatchback. all wires are right up to par. everything works, except the speedometer. anybody please help. could it be a fuse or something
was the cluster working before? are u sure all the wires are right? do u haev a picture on how this looks.
i plan on doing this, but i have no time at the moment cause i jsut bought a another hatch
the cluster was in my friend's 2000 si canadian model. my cx is a canadien model as well, i can get you a pic so that you can see what it looks like
Did you retrofit it? Aren't the 1992-1995 interchangeable and the 1996-2000 interchangeable? If you plug in to any other year other than the above years you'll need to modify the wiring harness? I'm guessing since the cluster is of a newer generation, maybe there is a conflict with your VSS to the signal of the cluster?
Kalokohan
Oct 23, 2001 07:01 AM
