how to adjust teh clutch? teh setup right now i cant even chirp 2nd
Old May 22, 2005 | 10:01 AM
CivicRaping's Avatar
Default how to adjust teh clutch? teh setup right now i cant even chirp 2nd
how to adjust teh clutch?i know where teh nut its but which way do i turn it teh setup right now i cant even chirp 2nd
Old May 22, 2005 | 10:29 AM
user 98292739's Avatar
what does adjusting teh clutch have to do with chirping 2nd? chirping relates to power and now high or low your pedal catches...what kind of car do you have? and model? mods?
Old May 22, 2005 | 01:48 PM
PURPLETERROR aka BIGMATT's Avatar
Default Re: how to adjust teh clutch? teh setup right now i cant even chirp 2nd (CivicRaping)
Maybe there is something wrong with your headers if you arent chirping 2nd
Old May 22, 2005 | 01:56 PM
Malgerus's Avatar
Default Re: how to adjust teh clutch? teh setup right now i cant even chirp 2nd (PURPLETERROR)
Learning how to spell "the" may help
If it's too low to the carpet it may not be fully engaging. Try tightening the adjustment nut a bit (gives the transmission "arm" less freeplay and raises the engagement point".
Old May 22, 2005 | 03:33 PM
Skunk.Werks's Avatar
Default Re: how to adjust teh clutch? teh setup right now i cant even chirp 2nd (Mr. S)
how the **** can you mispell THE 5 ******* times!!!
Old May 22, 2005 | 03:41 PM
ryan89crx's Avatar
Default Re: how to adjust teh clutch? teh setup right now i cant even chirp 2nd (Skunk.Werkz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Skunk.Werkz &raquo;</TD></TR><TR><TD CLASS="quote">how the **** can you mispell THE 5 ******* times!!!</TD></TR></TABLE>because he is trynig to impress you with his mad l33t skilz y0!!
Old May 22, 2005 | 03:55 PM
Turbo Dan's Avatar
i have the problem that my clutch engages once the clutch petal is almost all the way out, but it wont go into gear unless the petal is right to the floor, sometimes it even has a hard time going into gear all the way to the floor.
how can i fix this or is that adjuster at the tranny the only way?
Old May 22, 2005 | 05:44 PM
shivern's Avatar
Default Re: (Turbo Dan)
thats just how he types.. chill out ******s.
When my car was having problems chirping second, it wasnt the clutch adjustment, it was my timing and my TPS... however if your clutch is adjusted all the way out, there is high probability that you chewed it up pretty good. And also, if your clutch releases all the way at the floor, just try adjusting it down.. if it doesnt change Look into getting it replaced with a nice sticky clutch, 6 puck son
Old May 22, 2005 | 11:53 PM
31flavorscivic's Avatar
Default Re: (shivern)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo Dan &raquo;</TD></TR><TR><TD CLASS="quote">i have the problem that my clutch engages once the clutch petal is almost all the way out, but it wont go into gear unless the petal is right to the floor, sometimes it even has a hard time going into gear all the way to the floor.
how can i fix this or is that adjuster at the tranny the only way?</TD></TR></TABLE>
misaligned clutch?
p.s. I don't dump my clutch hard enough to chirp 2nd when i shift, I just don't find it necessary.
STEVE-O7
Oct 10, 2007 05:18 PM
MY SI
Sep 30, 2006 03:27 PM
G2ILS
Sep 26, 2004 01:52 PM
kseriesDC5
Mar 24, 2004 08:11 AM
bOOsTiNSoHcVtEc
Jun 19, 2003 10:25 PM
