axles
i tried to take my axles out today and when i was trying to get the nut off of my lower control arm (the one with the pin in it) but the nut and bolt keep spining at the same time therefor not letting me get the nut off.... does anybody out there have any solutions to this
yeah, that works good. also, you could try tapping the balljoint down with a hammer.
i've always got stuck ones off using a combination of those two methods.
if it's really stuck, though, you could probably use a nut splitter.
just have someone step on top/ or put their whole weight in the top of the whole hub/rotor assembly... cheapest trick in my book... no special tools needed.... the same goes when putting it back together after the jack trick doesn't work...
Did you take the pin out? Haha! I did this same thing and forgot. I had to replace my upper control arm because of that damn pin. It stripped the bolt that the castle nut threaded onto.
Mike Panic
21
Sep 22, 2005 06:37 PM
Capt. Jimbo McSubipants
Sep 15, 2005 11:26 AM
guttedhatch
May 28, 2003 08:09 AM
