Autometer install - it doesn't work
so today i wired everything from what i searched on..
red - to radio wire.. 12v
white- illumination
green - RPM input
black - to whatever is metal..
tell me if tahts correct?
i couldnt get it to light up or to work .. please help me someone .. 4 wires were cut off since my car is a 4 cylinder
Whats wrong with this setup?!
thanks.
white- illumination
green - RPM input
thanks.
You can get the docs on the Auto Meter web site.
Sounds like it's wired correctly. Since you have nothing, not even illum., I'd suspect the ground. Run a longer wire down to the kick panel area and find a good ground there.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ill »</TD></TR><TR><TD CLASS="quote">Since you have nothing, not even illum., I'd suspect the ground. </TD></TR></TABLE>
I was thinking the same. Good luck.
yeh it was the ground.. thanks!
now how do i adjust it? do i hold the red button and adjust the dial? or is there more to it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dungsta »</TD></TR><TR><TD CLASS="quote">its at 6 rpm when it starts</TD></TR></TABLE>
6 or 6000?
6 or 6000?
Double check all of your wiring.
If you did everything properly, there should be no problem.
If something does not work correctly, then you made a mistake and need to fix it.
GoLowDrew
Audio / Security / Video
Jul 17, 2006 11:05 PM
Rob_Dog
Nov 11, 2004 02:55 AM
tyflip2
May 26, 2004 07:13 AM
