Autometer install - it doesn't work
Old May 21, 2005 | 05:30 PM
dungsta's Avatar
Default installing an autometer but doesnt work need help
so today i wired everything from what i searched on..
red - to radio wire.. 12v
white- illumination
green - RPM input
black - to whatever is metal..
tell me if tahts correct?
i couldnt get it to light up or to work .. please help me someone .. 4 wires were cut off since my car is a 4 cylinder
Whats wrong with this setup?!
thanks.
Old May 21, 2005 | 06:09 PM
mugenracer's Avatar
Does your radio still work?
Also make sure you have grounded it properly, attaching it to metal wont always work as paint will mask the ground point
Old May 21, 2005 | 07:27 PM
Ill's Avatar
Ill
Default Re: installing an autometer but doesnt work need help (dungsta)
You can get the docs on the Auto Meter web site.
Sounds like it's wired correctly. Since you have nothing, not even illum., I'd suspect the ground. Run a longer wire down to the kick panel area and find a good ground there.
Old May 21, 2005 | 09:48 PM
Chris F's Avatar
Default Re: installing an autometer but doesnt work need help (Ill)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ill &raquo;</TD></TR><TR><TD CLASS="quote">Since you have nothing, not even illum., I'd suspect the ground. </TD></TR></TABLE>
I was thinking the same. Good luck.
Old May 21, 2005 | 10:56 PM
dungsta's Avatar
Default Re: installing an autometer but doesnt work need help (Chris F)
yeh it was the ground.. thanks!
now how do i adjust it? do i hold the red button and adjust the dial? or is there more to it?
Old May 22, 2005 | 11:28 AM
peeta's Avatar
hold the button and ask truong to help you dung
Old May 22, 2005 | 12:08 PM
dungsta's Avatar
Default Re: installing an autometer but doesnt work need help (peeta)
still need help..
Old May 22, 2005 | 01:40 PM
dungsta's Avatar
the rpm from the autometer isnt reading correct why is that?? someone please help
thanks
Old May 22, 2005 | 02:50 PM
Chris F's Avatar
How far off is it?
Old May 22, 2005 | 04:31 PM
dungsta's Avatar
its at 6 rpm when it starts
Old May 22, 2005 | 04:40 PM
Chris F's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dungsta &raquo;</TD></TR><TR><TD CLASS="quote">its at 6 rpm when it starts</TD></TR></TABLE>
6 or 6000?
Old May 22, 2005 | 05:30 PM
dungsta's Avatar
6 x 1000 rpm .. is it suppose to start at that number or could it be at 1 x 1000
Old May 22, 2005 | 05:32 PM
dungsta's Avatar
it idles at 6000 to mention..from the autometer dunno why i want it to idle at 1000
Old May 22, 2005 | 07:40 PM
Reid's Avatar
Global Moderator
Double check all of your wiring.
If you did everything properly, there should be no problem.
If something does not work correctly, then you made a mistake and need to fix it.
Old May 22, 2005 | 09:18 PM
Bbasso's Avatar
did you set the cyl choice? some have 4/6/8 switch on them
GoLowDrew
Audio / Security / Video
Jul 17, 2006 11:05 PM
3k9civic
Oct 19, 2005 09:35 PM
Rob_Dog
Nov 11, 2004 02:55 AM
tyflip2
May 26, 2004 07:13 AM
sPaRk'iT
May 3, 2003 07:57 PM
