D16Z6 and ZC SOHC Vtec?
Old May 21, 2005 | 01:07 PM
hbkid92591's Avatar
Default D16Z6 and ZC SOHC Vtec?
I have A CRX with a D16Z6, the thing is a blew a head and warped the **** out of the motor and now i am replacing it with a (ZC) motor according to what the engine code is. The ZC motor that i bought is identical to the d16z6, the thing is i wanted to if this motor (ZC) will pass smog with the set up i have becasue its a JDM motor. Also the CRX was smog legal with the D16Z6 on it i have the sticker that the refere puts on. Oh yeah i am CALI
Old Jun 1, 2005 | 08:45 PM
HipHapa-Eg's Avatar
From: Where friends and family is all that matters, CA
Default Re: D16Z6 and ZC SOHC Vtec? (hbkid92591)
ZC sohc vtec will pass smog.. my car did ..
Old Jun 1, 2005 | 09:16 PM
FalkenSiR's Avatar
Default Re: D16Z6 and ZC SOHC Vtec? (HAPA-EG)
The sohc vtec is the exact JDM version of the D16Z6. Some people will tell you that the cam is different, they'd make different power woudn't they...... So there you go, yes the engine will pass smog as long as you hook up all the visual smog stuff like valve cover ventilation tube, canister lines. And if you don't pass the test itself, go cheap and slap like 2 cats under the byotch...
Old Jun 1, 2005 | 10:12 PM
alky350's Avatar
but the z6 is a 1.6 and the sohc zc is a 1.5 right? how could it be the same?
Old Jun 2, 2005 | 06:57 AM
HipHapa-Eg's Avatar
naw the ZC sohc vtec is 1.6.. not 1.5
Old Jun 2, 2005 | 07:53 AM
DJ_SaNdOz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HAPA-EG &raquo;</TD></TR><TR><TD CLASS="quote">naw the ZC sohc vtec is 1.6.. not 1.5</TD></TR></TABLE>
That is correct. The D15B VTEC which is what you are probably thinking of is very similar, but 1.5 VS 1.6
Old Jun 2, 2005 | 08:00 AM
HumanResource's Avatar
It'll pass
With the Right ECU and smog devices you can even get it BAR cert'd.
Old Jun 2, 2005 | 11:38 AM
alky350's Avatar
Default Re: D16Z6 and ZC SOHC Vtec? (HumanResource)
steve from hmotorsonline said it was a 1.5
Old Jun 2, 2005 | 12:55 PM
Brownjd's Avatar
Default Re: D16Z6 and ZC SOHC Vtec? (alky350)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alky350 &raquo;</TD></TR><TR><TD CLASS="quote">steve from hmotorsonline said it was a 1.5</TD></TR></TABLE>
then he's talking about the D15B vtec motor.
Old Jun 2, 2005 | 05:10 PM
hbkid92591's Avatar
thanks for the replies, yeah i am just using the block. with the set up that i have it pass smog with the d16z6 its just replacing the engine block with ZC soch vtec which is the same as a d16z6 except it a JDM motor.
Old Jun 2, 2005 | 05:45 PM
c.dub's Avatar
Default Re: (hbkid92591)
i have a sohc zc its 1.6 *****
Old Jun 2, 2005 | 07:32 PM
alky350's Avatar
Default Re: (deviate_si)
im ******* lost....is it b-tek though?
http://www.hmotorsonline.com/s...30019
isnt this the motor your talking about, its a 1.5
Modified by alky350 at 6:14 AM 6/3/2005
Old Jun 3, 2005 | 08:24 AM
HipHapa-Eg's Avatar
Default Re: (alky350)
thats the D15b .. its a 1.5L vtec engine but the Zc sohc vtec is a 1.6L engine its basically the same as the D16z6 .. but its just a JDM engine
Old Jun 3, 2005 | 08:55 PM
alky350's Avatar
Default Re: (HAPA-EG)
where can i get one of these then..........
Old Jun 3, 2005 | 10:09 PM
HipHapa-Eg's Avatar
hmm im not sure.. mine came with my car.. haha..
just ask a place that sells swaps and maybe they can speacial order it.. or have one you can buy
civicdust
25
Mar 15, 2007 10:34 AM
ZCHF
Feb 4, 2005 12:09 PM
allmotorEG-SI
Nov 2, 2004 05:34 PM
NorcalHB94
Aug 12, 2004 04:42 PM
