zex cam help
Old May 21, 2005 | 12:46 PM
eg4door's Avatar
Default zex cam help
OK I got a d16z6 and a zex stage 2 cam from a y8. I know the cam will fit in the z6 but cam someone tell me around what degree I should set my gear at to start with.
Old May 21, 2005 | 12:48 PM
Kyles ej1's Avatar
Default Re: zex cam help (eg4door)
Old May 21, 2005 | 12:54 PM
eg4door's Avatar
I tought there was a timing difference because the cam is from the y8.
Old May 21, 2005 | 01:01 PM
blackeg's Avatar
there is, its like 4 or 5 degrees, but im not sure which way it is.....
Old May 21, 2005 | 01:03 PM
eg4door's Avatar
Default Re: zex cam help (blackeg)
Ok thanks, thats what I was thinking. Does anyone know witch way?
Old May 21, 2005 | 01:57 PM
eg4door's Avatar
If I start at o and after I try 5 degree advance or 5 degree reta. can I hurt the motor or will I be fine and it will just drive like ****?
Old May 21, 2005 | 05:13 PM
eg4door's Avatar
Also does an aem cam gear come with the little key for TDC ? cause the little key on the stock gear is one piece with the pulley.
ventturei27
Feb 16, 2007 07:25 AM
madcrossover
Nov 1, 2006 06:52 AM
portenio78
Apr 23, 2006 06:26 PM
rass1313
Mar 14, 2005 11:20 AM
mycvc8u2
Nov 13, 2003 01:51 AM
